Pardiso with Cygwin
Rawlins__David
I'm trying to run the sample program for Pardiso under Cygwin. This is my compile command:
g++ -o Pardiso.exe Pardiso.cpp -O3 C:/Program\ Files/Intel/MKL/10.1.1.022/ia32/lib/mkl_core.lib
I'm getting the following errors:
/cygdrive/c/DOCUME~1/Dave/LOCALS~1/Temp/ccVbk74J.o:Pardiso.cpp:(.text+0x6f): undefined reference to `_pardisoinit_'
/cygdrive/c/DOCUME~1/Dave/LOCALS~1/Temp/ccVbk74J.o:Pardiso.cpp:(.text+0x290): undefined reference to `_pardiso_'
/cygdrive/c/DOCUME~1/Dave/LOCALS~1/Temp/ccVbk74J.o:Pardiso.cpp:(.text+0x33b): undefined reference to `_pardiso_'
/cygdrive/c/DOCUME~1/Dave/LOCALS~1/Temp/ccVbk74J.o:Pardiso.cpp:(.text+0x40c): undefined reference to `_pardiso_'
/cygdrive/c/DOCUME~1/Dave/LOCALS~1/Temp/ccVbk74J.o:Pardiso.cpp:(.text+0x4ab): undefined reference to `_pardiso_'
Any help would be appreciated.
Dave
TimP
g++ -o Pardiso.exe Pardiso.cpp -O3 C:/Program Files/Intel/MKL/10.1.1.022/ia32/lib/mkl_core.lib
Dave
This is difficult, not something you could accomplish without thought and research. MKL for Windows would use Microsoft conventions, so there would be no appended _ such as gfortran would expect. You may also require the cygwin utility for converting path conventions. The mingw cross compiler might be somewhat more appropriate, as you would require Windows like run time support.
You could use ICL or CL under cygwin by opening their command prompt window and running cygwin.bat to superimpose cygwin paths. If you had set up the MKL paths first, as would happen with ICL Professional, you wouldn't have to deal with incompatible installation paths.
Rawlins__David
Quoting - tim18
Thanks, Tim. I think I'll just go with the VC++ compiler.
Dave
Todd_R_Intel
Tim is right to say this is non-trivial, but I did note that you also did not include all the libraries that are required.You'll need to add aninterface library to the link line and that will have the pardiso names that will call the functionality in the core library.The link line advisor might be helpful.
-Todd
Rawlins__David
-Todd
Thanks, Todd. I got it running by using the link line advisor.
Cheers,
Dave
