7298 Discussions
Performance test with Optimized LINPACK Benchmark
choi__minseok
Hi, I evaluated my embedded board, which has Xeon D 1.7GHz(8-cores, 12MB cache and 32GB DDR). The tool is Intel Optimized LINPACK Benchmark in MKL 2018. I expected about 400 GFLOPS but the result was about 145 GFLOPS. I would like to know the result is reasonable or not, and then how to get maximum performance. Thank you.
Ying_H_Intel
Hi Choi,
Could you please share some information like the OS etc.  and  how you expect about 400GFlops?
is it the Peak double floating points GLOPS 1.7G *8 * 256/64 x2(add+muti)x2(FMA)  = 217.6GFLP?   https://en.wikipedia.org/wiki/FLOPS
We had some explanation about how to use the benchmark in MKL developer guide
https://software.intel.com/en-us/mkl-linux-developer-guide-intel-optimized-linpack-benchmark-for-linux
and some MKL benchmark   https://software.intel.com/en-us/mkl/features/benchmarks  about the performance of Xeon.
Ying
choi__minseok
HI Ying,
My OS is CentOS 7.1(64-bit) and CPU is Xeon D-1539.
I expect based on the following.
409.6 GFLOPS = 1.6GHz  x 8 cores x 8(single precision data) x 2 FMAs x 2 dispatch ports
Thank you.
Ying_H_Intel
Get it. The benchmark return double precision data by default
Ying
Hanneken__Lukas
Hey Ying,
I know it's an old thread, but I guess here is my best shot. I want to read your guide since I'm investigating Performance Variation and the Intel HPL Linpack seems a fitting benchmark. But The links only says "Access Denied" for me.
Can I somehow get acces or find another guidance how to use it correctly?
Lukas
