Plz... help me.. i don't build fortran code..
Seung-min_J_
ithank you for read my message.
I don't build my fortran code.
This code name is "full matrix" and check the spending time 'LU decomposition, G-S, Jacobi'
Of course it included MKL and I installed my computer "Intel® Parallel Studio XE Composer Edition for Fortran OS X*
I tried build this code several time(frankly, over 100 times), but it generate this message
dyld: Library not loaded: libmkl_intel_lp64.dylib
  Referenced from: /Users/Rocket_man/Library/Mobile Documents/com~apple~CloudDocs/programming/Fortran/교수님 fortran 과제/Distribute/FullMatrix/axb13direct
  Reason: image not found
Trace/BPT trap: 5
my computer is OS X, and I was typing command blow.
1. cd  file location
2. ifort axb13direct.f -o axb13direct -L/opt/intel/compilers_and_libraries_2016.1.111/mac/mkl/lib -mkl
It is incorrect command line?
i really don't know how build fortran code connected mkl
PLz help me...
TimP
https://software.intel.com/en-us/inde-getting-started-compiler-on-osx describes the source command to set up the dynamic library paths for ifort and mkl.  This is needed both for link and to run the application.
Additional options are described by link advisor https://software.intel.com/en-us/articles/intel-mkl-link-line-advisor
