7303 Discussions
Potential bug in complex versions of mkl_?omatadd
AC_Simon33
Hi all,
I think came upon a bug in the mkl_?omatadd routine, especially the complex versions. If both matrices A and B are conjugate transposed, the matrix A is only conjugated. I configured the zomatadd.c example file that intel provided in order to show that this is the case:
As you can see the results are the same, which is incorrect. The second computation gives the wrong answer.
There are actually two more cases I found, where the result is wrong:
  1. A transposed and B conjugated: This combination conjugate transposes A instead of just transposing it.
  2. A conjugated and B transposed: This combination conjugate transposes B instead of just transposing it.
The example file is also attached for you to test it.
Simon
Gennady_F_Intel
what version of mkl do you use?
AC_Simon33
I'm using the mkl that comes with 2020 update 2 parallel studio. I'm on MacOS.
Gennady_F_Intel
Yes, you are right, that's the issue. You may escalate the case to Intel Online Service Center against Intel MKL.
AC_Simon33
Thanks for confirming the issue. There was already a ticket created by Khoros, is that enough?
Gennady_F_Intel
the fix of the issue has been released in the latest oneMKL 2021.2 which available for download.
Gennady_F_Intel
The issue is closing and we will no longer respond to this thread. If you require additional assistance from Intel, please start a new thread. Any further interaction in this thread will be considered community only.
