7303 Discussions
Preconditioned CG(RCI) initial residual computation
nityar
I am using RCI implementation of CG in MKL using dcg* API.
Can anybody explain how the initial residual is computed in preconditioned CG version. In non preconditioned version i can confirm it is  r0 =  square sum of (AX0 - b), if X0=0, is simply square sum of initial b . For preconditioned, how do we compute the value reported in parameter dpar_[2].
Also, in FGMRES the initial residue is norm2, i.e square root of residue reported in CG, any reason for this inconsistency?
thanks,
-Nitya
nityar
Can anybody please help on this?
Kirill_V_Intel
Hello Nitya,
I think it should be the squared norm of the preconditioned residual: || C^{-1} r0, r0 || where r0 is the initial residual r0 = (Ax - b) and C is the preconditioner. Let me know if it happens not to be so for you (I haven't done a full check).
Best,
Kirill
