Problem in MKL example for CG with SSOR
Tysseer_H_
I think there is something wrong with the sample "cg_ssor_precon_c.c" in the for loop that applies the SSOR iteration. The purpose of the loop is to apply SSOR repeatedly on the array &tmp[3*n]. but inside the loop every time it starts using tmp[2*n] and overwrites the previous value in tmp[3*n]. So effectively the loop is equivalent to a single SSOR run regardless of the number of iterations desired.
Can somebody help me confirm this?
Jing_Xu
Do you mean snippet from line 208 to line 228 in the c file?
tmp[3*n] will be updated in the function call mkl_dcsrsv (line 225).
In the function call mkl_dcsrmv (line 221), tmp[3*n] is used as input, so in each iteration, tmp[3*n] will be updated and the inputs to mkl_dcsrmv are different.
