Problem in calling MKL function of dgesvd
Jing_Q_
hi,
 I followed the Intel manual to call the the MKL routine of "dgesvd" in my code as
call dgesvd( 'S', 'N', m, n, a, lda, s, u, ldu, vt, ldvt, work, lwork, info)
If I set the compiler option with /iface:cref, the code works well. However, if the compiler option is set as /iface:cref /iface:mixed_str_len_arg, the code will report error during calling dgesvd as "Access violation reading location 0x0000000000000001". Because I have to keep the latter compiler option, how can I resolve the problem?
Thanks in advance for any suggestion!
Jing
The problem here is that you need a declaration of the routine that includes the NOMIXED_STR_LEN_ARG attribute (or DEFAULT). MKL doesn't provide one. I'm going to move this to the MKL forum as the folk there may have a ready solution for you. If not, I can make a suggestion.
I'm a bit puzzled that you're using mixed_str_len_arg with cref - that's an unusual combination. What requires it?
mecej4
Interfaces to Lapack routines are provided in file mkl_lapack.fi in the mkl/includes directory. You need to find the portion for dgesvd, modify those lines by specifying [fortran]cDEC$ ATTRIBUTES NOMIXED_STR_LEN_ARG :: DGESVD[/fortran] and include the modified interface block in your routine that calls dgesvd. If there are calls to other such MKL/LAPACK/BLAS routines, you would need to provide similarly modified interface blocks for them, as well.
I hope that you realize that all these non-standard fixes to get your code to work will negatively impact the portability of your code.
Chao_Y_Intel
Jing,
MKL library function used the nomixed_str_len_arg convention for the hidden-length character, if you call the library by the mixed_str_len_arg(with the /iface:mixed_str_len_arg swith), it may create the error. I think mecej4 provide a good suggestion, which will that function called by the nomixed_str_len_arg convention.
Chao
Jing_Q_
Hi, Steve:
Thanks for your help. Actually, The compiler option is forced by my customer and I am not very clear why they required this.
Mecej4 and Chao:
Many thanks for the solution. However, such approach seems not proper for me because my code will be deployed to many customers and I cann't require them to modify the mkl_lapack.fi on their computer.  Is that possible to solve this issue in other way?
Thanks again,
Jing
mecej4
You do not need to modify mkl_lapack.fi. Copy the five or six lines pertaining to dgesvd, add the attribute declaration, and put these lines into your code. We are talking about less than ten lines, not the ~15000 lines in the include file.
It is possible that if you explain the issues to your customers they will discover that they really do not want mixed_str_len_arg with cref, either! As Steve stated, this is an unusual combination and, if they cannot give the reasons for choosing it, perhaps it is not needed at all.
Jing_Q_
Hi, Mecej4:
Thanks a lot for your response. I followed your suggestion and add interface of dgesvd in my code as
      INTERFACE
         SUBROUTINE DGESVD(JOBU,JOBVT,M,N,A,LDA,S,U,LDU,VT,LDVT,WORK,LWORK,&
                           &INFO)
           !DEC$ ATTRIBUTES NOMIXED_STR_LEN_ARG :: JOBU,JOBVT
           CHARACTER          JOBU,JOBVT
           INTEGER            INFO,LDA,LDU,LDVT,LWORK,M,N
           DOUBLE PRECISION   A(LDA,*),S(*),U(LDU,*),VT(LDVT,*),WORK(*)
         END
      END INTERFACE
But the compiler report error during compiling as:
error #7796: Only a function or subroutine subprogram may have the !DEC$ ATTRIBUTES directive [NO]MIXED_STR_LEN_ARG specifier.   [JOBU]
error #7796: Only a function or subroutine subprogram may have the !DEC$ ATTRIBUTES directive [NO]MIXED_STR_LEN_ARG specifier.   [JOBVT]
Do you have any idea about that?
mecej4
Sorry, replace [fortran] !DEC$ ATTRIBUTES NOMIXED_STR_LEN_ARG :: JOBU,JOBVT[/fortran] by [fortran] !DEC$ ATTRIBUTES NOMIXED_STR_LEN_ARG :: DGESVD[/fortran] It would also be helpful if you show the source of a full example along with error messages, since the declarations often show why the error messages were generated.
Jing_Q_
The subroutine is likeing the following
      SUBROUTINE FULLSOLUTIONPATH(FLAG,NT,SNAPSHOT,SPNUM)
      IMPLICIT NONE
      INTERFACE
                           &INFO)
         END
      END INTERFACE
      LWORK = -1
      ALLOCATE(WORK(1))
      CALL DGESVD('S','N',MT,NT,SNAPSHOT_tmp,MT,SINGULARVALUE, &
                  & Utmp,MT,VT,ONE,WORK,LWORK,INFO)
      LWORK = INT(WORK(1))
      DEALLOCATE(WORK)
      ALLOCATE(WORK(LWORK))
      END SUBROUTINE  FULLSOLUTIONPATH
Where should I  place the
Thanks in advance!
mecej4
In the line containing "!DEC$..." in your listing, replace "JOBU,JOBVT" by "DGESVD".
Jing_Q_
Hi, Mecej4:
It works now. Thank you very much!
Jing
