7299 Discussions
Problem linking C Sparse BLAS routines with gcc
mbhealy
I am trying to use the function mkl_dcscmm in my C++ code. I am using the gnu compiler and linker. When the linking stage begins I use this call:
g++ -ansi -pedantic -Wall -O3 netlist.o domain.o createMats.o main.o -o circuit libs/SuperLU_3.0/libsuperlu_3.0.a -Llibs/imkl/mkl/lib/em64t libs/imkl/mkl/lib/em64t/libmkl_intel_lp64.a libs/imkl/mkl/lib/em64t/libmkl_intel_thread.a libs/imkl/mkl/lib/em64t/libmkl_core.a libs/imkl/mkl/lib/em64t/libguide.a -lpthread -lm
and the output is full of errors that look like this:
libs/imkl/mkl/lib/em64t/libmkl_core.a(_def_mkl_dcscmm_lp64.o)(.text+0x7b0): In function `mkl_spblas_lp64_def_mkl_dcscmm':
: undefined reference to `mkl_spblas_lp64_cspblas_dcsrmmgen'
libs/imkl/mkl/lib/em64t/libmkl_core.a(_def_mkl_dcscmm_lp64.o)(.text+0x828): In function `mkl_spblas_lp64_def_mkl_dcscmm':
: undefined reference to `mkl_spblas_lp64_dcsrmmgen'
libs/imkl/mkl/lib/em64t/libmkl_core.a(_def_mkl_dcscmm_lp64.o)(.text+0x8d4): In function `mkl_spblas_lp64_def_mkl_dcscmm':
: undefined reference to `mkl_spblas_lp64_cspblas_dcsrmmtr'
libs/imkl/mkl/lib/em64t/libmkl_core.a(_def_mkl_dcscmm_lp64.o)(.text+0x96b): In function `mkl_spblas_lp64_def_mkl_dcscmm':
: undefined reference to `mkl_spblas_lp64_dcsrmmtr'
libs/imkl/mkl/lib/em64t/libmkl_core.a(_def_mkl_dcscmm_lp64.o)(.text+0xd09): In function `mkl_spblas_lp64_def_mkl_dcscmm':
: undefined reference to `mkl_spblas_lp64_cspblas_dcsrmmskew'
I tried grepping through the mkl lib directory for things like mkl_spblas_lp64_cspblas_dcsrmmtr and I found that they are referenced in these files:
Binary file libmkl_core.a matches
Binary file libmkl_gnu_thread.a matches
Binary file libmkl_intel_thread.a matches
Binary file libmkl_sequential.a matches
Binary file libmkl_def.so matches
Binary file libmkl_gnu_thread.so matches
Binary file libmkl_intel_thread.so matches
Binary file libmkl_mc.so matches
Binary file libmkl_p4n.so matches
Binary file libmkl_sequential.so matches
None of these actually look like they contain the definitions I'm looking for and when I include the ones not already included I get other linking errors. The example in the mkl/examples/spblas is only for fortran and I have included all the files that it uses. Any suggestions?
TimP
As there are circular references in the MKL libraries, for static linking, you must either repeat the list of libraries 3 times (more, if in wrong order), or set the -Wl,--begin-group .... -Wl, --end-group (or equivalent) flags, as shown in the MKL docs. If those options go wrong, it could be a problem with out of date binutils or gcc.
mbhealy
Thanks! That worked. I don't know why I didn't see that before. I had used those lines before for a different example I was working with.
For those interested, here is the linking line that worked for me:
g++ -ansi -pedantic -Wall -O3 netlist.o domain.o createMats.o main.o -o circuit libs/SuperLU_3.0/libsuperlu_3.0.a -Llibs/imkl/mkl/lib/em64t libs/imkl/mkl/lib/em64t/libmkl_intel_lp64.a -Wl,--start-group libs/imkl/mkl/lib/em64t/libmkl_intel_thread.a libs/imkl/mkl/lib/em64t/libmkl_core.a -Wl,--end-group libs/imkl/mkl/lib/em64t/libguide.a -lpthread -lm
