Problem with "zsptrf"
cesarpradosboda
when I use the function "zsptrf" of LAPACK library for resolve alinear system, the program work whit a complex matrix, when this matrix is of 2597 unknowns, the results are right, but when the matrix is over 5837 unknowns the result aren't right why? I use the same "call" with the same passing parameters.
