Problem with scale factor in 2d fft
flexwang
I am using mkl to do a 2d image fft. First, I used mkl to compute forward the 2d fft of the initial image and I computed backward. I think it should get a image where every pixel gray scale is scaled by the factor (imagewidth*imageheight). However, only the right half of the image is scaled, and the other half is just the original image. How did that happen!
VipinKumar_E_Intel
Can you attach a testcase that reproduced this?
--Vipin
