Problem with upgrade from MKL 10 to 2013
Don_G_
What I used Visual Studio 2010 with MKL 2013 installed to upgrade a complex C#/Fortran solution  from Visual Studio 2008/Intel fortran 10.  When I build the project, I get an error linking the Fortran DLL.   The error is LNK2019: unresolved external symbol _MKL_FREEBUFFERS referenced in function _RUN_CTRL.
What can I do to resolve this error?
Don_G_
Aha, changed the call to MKL_Free_Buffers  and that worked.
mecej4
Check the spelling of the routine in the manual for the MKL version that is being used. I believe that it should be mkl_free_buffers.
Ying_H_Intel
Hi Don,
Yes, could you please find the exact MKL version, MKL library being used or provide us a small test case?
And the latest version is MKL 11.3 update 1. and the documentation was
https://software.intel.com/en-us/node/471174
Syntax
call mkl_free_buffers
Fortran Include Files/Modules
  • Include file: mkl.fi
  • Module (compiled): mkl_service.mod
  • Module (source): mkl_service.f90
    Ying
Don_G_
In VS on the Tools menu it shows Intel Composer XE 2013 ​SP1.  I am not sure how to get the exact MKL library version.
Don_G_
This is the form of the call to freebuffers in the fortran module:
    CALL MKL_FreeBuffers()
So I added the include statement:
INCLUDE 'mkl.fi'
at the top of the module.
  This did not solve the problem.
Don_G_
Ying_H_Intel
Hi Don,
Great news!  as mejec mentioned, we change the API name MKL_FreeBuffers() in these version  between Intel Composer XE 2013 ​SP1 and Intel fortran 10) . You can open the mkl.h or mkl.fi , which is supposed in <MKl insatll direcory>\include\mkl.h|mkl.fi  to find the exact version.
and check the function's declaration in mkl_service.fi. for example
 INTERFACE
      subroutine MKL_FREE_BUFFERS()
      END
      END INTERFACE.
Ying
