Problem
Martin_Fuchs
Hi everyone, I am trying to run a simple fft from dfti routine of the latest MKL modules... I used:
USE mkl_dfti
TYPE(DFTI_DESCRIPTOR), POINTER :: My_Desc_Handle
status = DftiCreateDescriptor(My_Desc_Handle, DFTI_DOUBLE, &
DFTI_REAL, 1, alpha+2)
WRITE(*,*) 'Status 1',status,alpha
status = DftiSetValue(My_Desc_Handle, DFTI_PLACEMENT, DFTI_NOT_INPLACE)
WRITE(*,*) 'Status 2',status
status = DftiCommitDescriptor(My_Desc_Handle)
WRITE(*,*) 'Status 3',status
status = DftiComputeForward(My_Desc_Handle, Vlm, DFTV)
WRITE(*,*) 'Status 4',status
status = DftiFreeDescriptor(My_Desc_Handle)
WRITE(*,*) 'Status 5',status
... alpha= 20
I get as status
2
5
5
5
5
The DFTV array coming from the routine is zero...
I compiled with the command on a linux machine:
$(f90) /DGFI16/home/fuchs/intel/Compiler/11.1/072/mkl/include/mkl_dfti.f90 Constants.f90 Flmk.f90 /DGFI16/home/fuchs/intel/Compiler/11.1/072/mkl/include/lapack.f90 SubsTWFD.f90 Legendre.f90 vecmat.f90
ar -rv $(lib) mkl_dfti.o Constants.o Flmk.o lapack.o SubsTWFD.o Legendre.o vecmat.o
can someone tell me what went wrong ???
barragan_villanueva_
Valued Contributor I
It's possibleto get DFTI-messages on given statuses instead of numbers.
See $MKLROOT/examples/dftf/sources for details.
E.g.
Status = DftiCreateDescriptor(hand, DFTI_DOUBLE, DFTI_REAL, 1, n)
if (.NOT. DftiErrorClass(Status, DFTI_NO_ERROR)) then
print *,'Status 1:', DftiErrorMessage(Status)
end if
As to your problem: could you please send small standalone test-case and compilation line with MKL-libraries to reproduce that?
Martin_Fuchs
Thanks Victor I think I managed the problem, it might be the ilp64 library; instead I used the lp64 library... Now I good some memory problem... But at least the dfti return is not zero
Well, to get correct Fortran code to work with MKL ILP64 library it needs to use compiler options:
-i8 for Intel Fortran
-fdefault-integer-8 for GNU Fortran
