Problems calling mkl_rt.dll in C# / program crashes
Philipp_W_
we are using Intel MKL 11.02. since a few weeks and a first C++ example calling the includes works fine. But we have some trouble to import the mkl_rt.dll in C#. When calling the dll the program crashes without any notice. We have tried it for some functions (MKL_Set_Num_Threads, VDDIV, VDADD, DASUM, MKL_Get_Max_Threads) and always get the same result. Additionally we tested 32bit and 64bit versions of mkl_rt.dll and also the Intel C#-example "vddiv" - and result every time in a uncommented program stop.
namespace MKL_Test
public unsafe class MKL_Wrapper
[DllImport("mkl_rt.dll", CallingConvention = CallingConvention.Cdecl, ExactSpelling=true, SetLastError = false, EntryPoint = "MKL_Get_Max_Threads")]
public static extern int Get_Max_Threads();
The function is then called by:  int anzahl = MKL_Test.MKL_Wrapper.Get_Max_Threads();
Are there any further issues we don't have taken into account?
Our test files are attached.
Many thanks in advance,
Philipp Wollmann
SergeyKostrov
Valued Contributor II
>>...The function is then called by: int anzahl = MKL_Test.MKL_Wrapper.Get_Max_Threads(); I'd like to confirm that a pure C/C++ test with the function MKL_Get_Max_Threads works. Is that correct?
Philipp_W_
Yes, a C++ test using "mkl.h" and "MKL_Get_Max_Threads();" works fine.
For the dll import in C# we used the file from the redistribution folder.
SergeyKostrov
>>...When calling the dll the program crashes without any notice... Could you verify a list of loaded DLLs for C/C++ test and C# test? Here are instructions: - Compile debug versions of both applications - Start Debugging ( F10 ) for C/C++ application, do something and exit - Take a look at Output Window of Visual Studio for a complete list of loaded DLLs - Start Debugging ( F10 ) for C# application, do something and exit - Take a look at Output Window of Visual Studio for a complete list of loaded DLLs - Find all loaded Intel DLLs for both cases and compare ( take into account that full paths to DLLs are displayed ) Please posts results of your investigation.
SergeyKostrov
Another verification for C# application: - Verify that a 32-bit C# application uses 32-bit Intel DLLs and - Verify that a 64-bit C# application uses 64-bit Intel DLLs
Philipp_W_
Hi Sergey,
thanks for your advice. I checked the mentioned tasks and found, that "intel_mkl_thread.dll" was missed in the C# project - now it runs. Interestingly this dll was not indicated by an error prompt, other missed dll files were mentioned by an error message.
Many thanks for the solution!
Philipp
