7303 Discussions
Problems using Nonlinear Least Squares Solver (without Constraints)
queinferno
Hi all,
I'm want to use the nonlinear solverof MKL but I couldn't acomplish my mission til now! I have readthe example offered with the documentation and some forumthreads, but there might still be somethingthat I didn't understand. I would appreciate some help.
My experimental code:
I tried to use the solver to fit something really easy. Let my function to be a curve with10 points (i=0:10)given by a*(i-5)^2 + b. My "true coefficients" are a = 5 and b = 6 and I give the solver a=8 and b = 10 as a first estimation. The finals coefficients I got were: a = 6.37 and b = 2.66. What's wrong?
Here my code:
bool
CurveFit::executeFitting(void)
int nCoefficientsSize = 2;
int nValuesSize = 10;
int nMaxNumberOfIterations = 1000000;
int nMaxNumberOfIterationsTrialStep = 100;
double dSizeOfTrueRegion = 100;
double coefficients[2] = {8,10};
double stopCriteriaPrecisions[6] = {0.00001, 0.00001, 0.00001, 0.00001, 0.00001, 0.00001};
double values[10];
double jacobian[10];
_TRNSP_HANDLE_t handle;
int nOK = dtrnlsp_init(&handle, &nCoefficientsSize, &nValuesSize, &coefficients[0], &stopCriteriaPrecisions[0], &nMaxNumberOfIterations , &nMaxNumberOfIterationsTrialStep, &dSizeOfTrueRegion);
memset(&values[0], 0, nValuesSize*sizeof(double));
memset(&jacobian[0], 0, nValuesSize*nCoefficientsSize*sizeof(double));
int nRCI_Request = 0;
while( nRCI_Request >= 0)
if (nRCI_Request == 2)
djacobi (extended_powell, &nCoefficientsSize, &nValuesSize, &jacobian[0], &coefficients[0], &stopCriteriaPrecisions[0]);
else if(nRCI_Request == 1)
extended_powell (&nValuesSize, &nCoefficientsSize, &coefficients[0], &values[0]);
nOK = dtrnlsp_solve(&handle, &values[0], &jacobian[0], &nRCI_Request);
int nNumberOfIterations, nStopCriteriaValue;
double nFirstResidual, nFinalResidual;
nOK = dtrnlsp_get(&handle, &nNumberOfIterations, &nStopCriteriaValue, &nFirstResidual, &nFinalResidual);
nOK = dtrnlsp_delete(&handle);
return true;
/* routine for extended powell function calculation
m in: dimension of function value
n in: number of function variables
x in: vector for function calculation
f out: function value f(x) */
void CurveFit::extended_powell (int *m, int *n, double *x, double *f)
double a = *x;
double b = *(x+1);
double a0 = 5;
double b0 = 6;
int nSize = *m;
double dCenter = 5;
double dist, yValue, fValue;
for (int i = 0; i < nSize; i++)
dist = i - dCenter;
yValue = a0*dist*dist + b0*dist;
fValue = a*dist*dist + b*dist;
*(f + i) = yValue - fValue;
return;
thank you, Vanessa
queinferno
my mistake!!! :-/
the jacobian vector has wrong size....
