Problems with Intel MKL 10.1 custom DLLs
fullung
Hello all
I am having some problems with the Intel MKL 10.1 custom DLL builder.
Neither the 32-bit nor the 64-bit DLLs seem to work.
I run "nmake ia32" inside the VS2008 Command Prompt. If I open this DLL with Dependency Walker, everything seems fine. However, when I try to load this DLL in my application (Java, using the JNA library), the following error dialog appears:
Microsoft Visual C++ Runtime Library
Runtime Error!
Program: C:\Program Files (x86)\Java\jdk1.6.0_06\bin\javaw.exe
R6034
An application has made an attempt to load the C runtime library incorrectly.
Please contact the application's support team for more information.
OK
With the 64-bit DLL built with "nmake em64t", I also get an error when JNA tries to load it. When I examine this DLL in the 64-bit version of Dependency Walker, it seems the DLL is linked to 64-bit versions of the system libraries, except for being linked to a 32-bit version of msvcr90. I thought this might be a problem with Dependency Walker, but if I examine other MKL DLLs, it finds them to be linked to the 64-bit version of msvcr90. The Dependency Walker error in this case is:
Error: At least one module has an unresolved import due to a missing export function in an implicitly dependent module.
Error: Modules with different CPU types were found.
I can load custom DLLs and call functions from IPP 6 without problems, so I suspect the problem is the MKL DLLs rather than with my other software (Java and JNA).
More pertinent information: I am using Vista x64 SP1 and Visual Studio 2008 SP1. I had to comment out the BUFLIB line in the makefile to get the MKL custom DLLs to build.
Any help would be greatly appreciated.
Albert
