Problems with Static Linking with MKL
zeev_B_
Hello, We need your assistance with using the MKL library. We are using the following configuration: OS – Ubuntu 12.04 LTS 32 bit. SDK – Eclipse 3.7.2. Compiler - Intel IA-32 C++ Compiler (v13.0.0), using composer_xe_2013.1.117. We are trying to run the following code: int main() { double a[100], yr[100], yi[100[ ; int n = 100; vdSinCos(n,a,yi,yr); double p1r[10], p2r[20], resultrr[30]; int n1 = 10, n2 = 20, start = 0, stride = 1; vSLConvTaskPtr m_task; vsldConvNewTask1D(&m_task, VSL_CONV_MODE_AUTO, n1, n2, n1); vslConvSetStart(m_task, &start); vsldConvExec(m_task, &p1r[0], &stride, &p2r[0], &stride, &resultrr[0], &stride); vslConvDeleteTask(&m_task); } When we define dynamic linking to the MKL library the compilation and linking phase are completed with success and we can run the program. Our problem starts when we are trying to link the MKL statically. From our knowledge, when using the –mkl flag the static linking should work without and further requirement of us to specify any additional libraries of the MKL that should be linked since using the –mkl flag should enable all the library functionality. But still, we are getting the following errors during the linking phase: Building target: TestMath Invoking: Intel IA-32 C++ Linker icpc -static -L/opt/intel/composer_xe_2013.1.117/mkl/lib/ia32 -mkl=sequential -o "TestMath" ./src/TestMath.o /. src/TestMath.o: In function `main ' : / home/user/workspace/TestMath/Debug/../src/TestMath.cpp:17: undefined reference to `vdSinCos ' / home/user/workspace/TestMath/Debug/../src/TestMath.cpp:23: undefined reference to `vsldConvNewTask1D ' / home/user/workspace/TestMath/Debug/../src/TestMath.cpp:24: undefined reference to `vslConvSetStart ' / home/user/workspace/TestMath/Debug/../src/TestMath.cpp:25: undefined reference to `vsldConvExec ' / home/user/workspace/TestMath/Debug/../src/TestMath.cpp:26: undefined reference to `vslConvDeleteTask ' We have tried to manually link specific libraries in order to overcome this linking issue and only after we have specifically linked the mkl_intel, mkl_core and mkl_sequential libraries the project linking phase completes without any error, with the exception of the vsIdConvExec function, so we have commented. make -k all Building file: ../src/TestMath.cpp Invoking: Intel IA-32 C++ Compiler icpc -g -mkl=sequential -I/opt/intel/composer_xe_2013.1.117/mkl/include -MMD -MP -MF"src/TestMath.d" - MT"src/TestMath.d" -c -o "src/TestMath.o" "../src/TestMath.cpp" Finished building: ../src/TestMath.cpp Building target: TestMath Invoking: Intel IA-32 C++ Linker icpc -static -L/opt/intel/composer_xe_2013.1.117/mkl/lib/ia32 -mkl=sequential -o "TestMath" ./src/TestMath.o -lmkl_intel -lmkl_core -lmkl_sequential Finished building target: TestMath When we have tryied to uncomment the call to the vsIdConvExec function we got enormous number of undefined reference errors. Even when we`ve tried to statically link all the .a libraries in the ia32 folder we still got the undefined reference erros. Please advise how to configure correctly our static linking (shouldn’t –mkl be enough?) since dynamic linking is not possible in order environment. Thanks.
mecej4
When you use static linking, and you list one or more .o objects after one or more static libraries that contain symbols needed by the object(s), the linking will fail. See, for example, the explanation in http://eli.thegreenplace.net/2013/07/09/library-order-in-static-linking/ .
The solution is quite simple: list the names of the .o files to be linked before the list of libraries in the command that invokes the linker ld. In your makefile, you should have something similar to:
[bash]
icpc -static ./src/TestMath.o -L/opt/intel/composer_xe_2013.1.117/mkl/lib/ia32 -mkl=sequential -o "TestMath"
[/bash]
TimP
static linking of MKL has the additional problem of circular dependencies which has to be resolved by --start-group .....   --end-group linker directives, and full path names of the libraries, as shown in the MKL link advisor  http://software.intel.com/en-us/articles/intel-mkl-link-line-advisor
-mkl=sequential is a good idea for initial testing, but I think it may not work with -static.
Ying_H_Intel
As mecej4 and Tim pointed out,  one key is  the order of linked library,  another key is the -mkl and -static combination.  Here is one KB talking about the problem:
http://software.intel.com/en-us/articles/link-error-when-static-linking-to-intel-mkl-on-linux-6
So the recommend static link line is
icpc -intel-static ./src/TestMath.o -L/opt/intel/composer_xe_2013.1.117/mkl/lib/ia32 -mkl=sequential -o TestMath
Ying
miro_ilias
this simple Fortran90 program does not link statically with --mkl=sequential/parallel:
[email protected]:~/Work/qch/software/software_projects/autocmake_devel/autocmake_miroi/test/fc_blas/build_ifort_mklpar_static/./mnt/apps/intel/composer_xe_2013_sp1.1.106/bin/intel64/ifort   -static-intel  -mkl=sequential    -O3 src/CMakeFiles/example.dir/example.f90.o  -o bin/example
src/CMakeFiles/example.dir/example.f90.o: In function `MAIN__':
/home/milias/Work/qch/software/software_projects/autocmake_devel/autocmake_miroi/test/fc_blas/src/example.f90:(.text+0x37a): undefined reference to `dgemm_'
[email protected]:~/Work/qch/software/software_projects/autocmake_devel/autocmake_miroi/test/fc_blas/build_ifort_mklpar_static/./mnt/apps/intel/composer_xe_2013_sp1.1.106/bin/intel64/ifort   -static-intel  -mkl=parallel    -O3 src/CMakeFiles/example.dir/example.f90.o  -o bin/example
Without -static-intel flag it works:
[email protected]:~/Work/qch/software/software_projects/autocmake_devel/autocmake_miroi/test/fc_blas/build_ifort_mklpar_static/./mnt/apps/intel/composer_xe_2013_sp1.1.106/bin/intel64/ifort    -mkl=parallel    -O3 src/CMakeFiles/example.dir/example.f90.o  -o bin/example
[email protected]:~/Work/qch/software/software_projects/autocmake_devel/autocmake_miroi/test/fc_blas/build_ifort_mklpar_static/.bin/example
 PASSED
Any help ? I guess --mkl=<sequential/parallel/cluster> is intended with dynamical linking only. Comments please ?
