Question about sparse matrix
kim__seongik
1. Is there an appropriate subroutine in mkl with respect to matrix assembly?
    I made and used by myself, but it takes too long.
    I want to something like below expression in fortran
   (example-matlab case) global_matrix(dof,dof) = global_matrix(dof,dof) + element_matrix
2. Is there any subroutine in mkl to create a sparse matrix format?
3. Which subroutine should be used for sparse matrix multiplication?
   (example -matlab case) A*x=b  (A : sparse matrix, x: vector, b:vector)
4. Is there a subroutine that can do in fortran mkl how to delete certain rows and columns?
   (example -matlab case)  matrix(dof,dof) = [];
5.  I want to use scalapack of intel mkl, but can't I use it except cluster??
    When I used scalapack's dlasrt2 on the desktop, error lnk 2019 occurred.
Gennady_F_Intel
1. there are no such routines
2. you can try to use conversion from/to dense - CSR, CSC, and others supported sparse formats. Please refer to use MKL Reference to see more details
3.  please refer to the documentation follow with this link https://software.intel.com/content/www/us/en/develop/documentation/mkl-developer-reference-c/top/blas-and-sparse-blas-routines/sparse-blas-level-2-and-level-3-routines/sparse-blas-level-2-and-level-3-routines-1.html
You may see a lot of m*v  routines with different sparse formal, e.x - tmkl_?csrgemv
4. There is no such routine.
5. you can build and run on the SMP system as well.
how did you link the case? how did you run it?
Gennady_F_Intel
Gennady_F_Intel
regarding the #5 - please check the mkl linker adviser how to properly link with the ScaLAPACK components
kim__seongik
Thank you for your reply !!
In number 5 my setting is below figure::
Gennady_F_Intel
Gennady_F_Intel
I missed that you use windows:
the linking would look like as follows: /Qmkl=cluster
