Random Number Generator
Ahmadi__Afshin
I have developed a function to generate a vector of random numbers. However, there are two problems:
1. When the number of random numbers to be generated is too large (e.g. 50000^2), it will output: MKL ERROR: Parameter 3 was incorrect on entry to vdRngUniform.
2. When the left bound is a positive number (i.e. a = 300 b = 100), the function violates the left bound condition and returns minimum value of zero! However, if 'a' is a negative number, it works correctly!
Can you please help? Thank you.
Afshin
int RNG_UNIF ( long int N, double a, double b, double *P )
    // N number of random values to be generated
    // a is the left bound
    // b is the right bound
    VSLStreamStatePtr stream;
    int errcode = 0;
    srand(time(0));
    long seed = rand();
    /***** Initialize *****/
    errcode = vslNewStream( &stream, VSL_BRNG_MT2203, seed );
    if (errcode != 0) goto err;
    /***** Call RNG *****/
    errcode = vdRngUniform( VSL_RNG_METHOD_UNIFORM_STD_ACCURATE, stream, N, P, a, b );
    vslDeleteStream(&stream);
    err:
    return errcode;
Gennady_F_Intel
did you link with ILP64 libraries?
Ahmadi__Afshin
Yes. I used the following switches: -lmkl_intel_thread -lmkl_core -lmkl_intel_lp64 -liomp5 -O2
I am using Intel MKL 2019 in Linux environment. How about the second problem?
Gennady_F_Intel
50000^2 > int 32, therefore you have to link with ILP64 libs instead of LP64 ones. Please check user's guide or mkl linker adviser how to link properly
