7300 Discussions
Reusing Dfti Descriptor even after comitting it
subramanian__vedapra
Can we do the following
              status = DftiCreateDescriptor( &ifft_handle, DFTI_SINGLE,DFTI_COMPLEX, 1, 5400);
              for(int i = 0; i < 100; i++) {
                        float scale = 1 * i;
                        status = DftiSetValue( ifft_handle, DFTI_FORWARD_SCALE, scale);
                        status = DftiCommitDescriptor( ifft_handle);
                        // inovke fft
             status = DftiFreeDescriptor (&ifft_handle);
So can we reuse the Dfti descriptor even after comitting?
Zhang_Z_Intel
Yes. This is a supported usage model. As long as you re-commit the descriptor after modifying it using DftiSetValue, you can use it again.This is what the documentation of DftiCommitDescriptor says:
If you call the DftiSetValue function to change configuration parameters of a committed descriptor see Descriptor Configuration Functions), you must re-commit the descriptor before invoking a computation function. Typically, a committal function call is immediately followed by a computation function call
