ScaLAPACK Example in C
schmmd
Does anyone know of a ScaLAPACK example in C? I need to write a simple program that runs psgesvd on a single machine but utilizing all of the cores. Is this the write approach to run an svd decomposition using multiple cores? I do not believe that sgesvd takes advantage of more than one core (at least, in my example it does not).
ArturGuzik
Valued Contributor I
Quoting - schmmd
you don't need ScaLAPACk to do it (on single machine). Just "simple" MKL LAPACK and linking with libiomp5 lib. See the docs (Chapter 5 of User's Guide). Which platform (IA32/x64) are you on?
A.
schmmd
Well, that's great news that I can just link with that library. I am running on x64. Thanks for the reference to the chapter in the user guide too. I will figure this out.
If anyone does know of a C example for ScaLAPACK I would still be interested, however. I will likely need to expand my SVD to a cluster.
Gennady_F_Intel
There are no such examples for ScaLapack functionality.
--Gennady
Tabrez_Ali
Quoting - schmmd
Here's a trivial Fortran example. You should be able to figure out the equivalent C code easily.
