7303 Discussions
Segmentation Fault in poisson solver (d_commit_helmholtz_2d)
zudol0104
Hi I am a new user to oneMKL.
I am trying to solve a 2-dimensional Poisson Equation with oneMKL's Fast Poisson Solver. I am using C++ to test the Example (MKLRoot/examples/f/pdepoisson) in the library.
It works fine until d_init_helmholtz_2d(), then I get a Segmentation fault in d_commit_helmholtz_2d(). I've attached the code below, please let me know what the issue is.
size_t total_size=(nx+1) * (ny+1);
double* f = new double[total_size];
double* bd_ax = new double[ny+1];
double* bd_bx = new double[ny+1];
double* bd_ay = new double[nx+1];
double* bd_by = new double[nx+1];
DFTI_DESCRIPTOR_HANDLE xhandle;
MKL_INT* ipar = new MKL_INT[128];
double* dpar = new double[5*(nx/2)+7];
MKL_INT stat
d_commit_helmholtz_2d(f, bd_ax, bd_bx, bd_ay, bd_by, &xhandle, ipar, dpar, &stat);
mecej4
Mixing portions of different version of MKL can lead to problems.
Rather than relying on Cmake to ascertain the version of MKL that is actually being used, you may add a call to mkl_get_version_string in your code, and print out the string that is returned. There is a related routine, mkl_get_version, which allows you to retrieve a collection of integers that make up the version number.
mecej4
I built the example using the source file d_Helmholtz_2D_c.c in the MKL distribution and ran the resulting EXE (LP64 version) on Windows 11. The program ran normally and produced the expected output; I used the current versions of the Intel C compiler (icl, icx) and MKL in OneAPI 2023.2.0.
I found it confusing to see you saying that you used the example source file in MKLRoot/examples/f/pdepoisson. That would be a Fortran version, whereas the lines of code that you showed are in C++.
Please state whether you changed the source file in question in any way, and state how you built and ran the program.
zudol0104
Thank you for your quick response.
I tested it with the C code inside the oneMKL Package (sorry for the typo /f -> /c).
The MKL version is either 2022.2.1 or 2023.2.0. I used cmake's find_package and it found 2 versions, I'm not sure which one I used as I don't have much knowledge of cmake, but I saw the following message.
Found MKL: /oneapi/mkl/2022.2.1/lib/intel64/libmkl_intel_ilp64.so
Found MKL: /oneapi/mkl/2022.2.1/lib/intel64/libmkl_core.so
Found MKL: /oneapi/mkl/2022.2.1/lib/intel64/libmkl_intel_thread.so
Found MKL: /oneapi/compiler/2023.2.0/linux/compiler/lib/intel64_lin/libiomp5.so
The Build System State is as follows
OS= "Red Hat Enterprise Linux Server", Version="7.6 (Maipo)".
C Compiler = /oneAPI/compiler/2021.2.0/linux/bin/intel64/icc
CXX compiler = C Compiler = /oneAPI/compiler/2021.2.0/linux/bin/intel64/icpc
Could this be due to different versions of the compiler and mkl?
I'll try to test it by setting the two versions to be the same.
mecej4
zudol0104
Mixing MKL versions seems to be the problem.
I added the following syntax to "CMakeLists.txt" to ensure that I use the same version when building d_Helmholtz_2D_c.c.
set(MKL_ROOT /my/dir/oneapi/mkl/latest)
list(APPEND CMAKE_MODULE_PATH "MKL_ROOT/lib/cmake")
VarshaS_Intel
 It’s great to know that the issue has been resolved, in case you run into any other issues please feel free to create a new thread.
Have a Good Day!
Thanks & Regards,
Varsha
