Segmentation fault in dsyevr.
valeriyfedotov
Hello. I cant make dsyevr work properly. After some tries I wrote simple example of my problem. There are two calls to dsyevr that work and two that don't. But the arguments look fine and differ with working examples too little. I can't understand what's the problem. My MKL version is 10.2.1.017, and I compile it with command
icc stuff.c -I"opt/intel/mkl/10.2.1.017/include/" -L"/opt/intel/mkl/10.2.1.017/lib/" -lmkl_core -lmkl_intel_thread -lguide -lpthread -lmkl_lapack -lmkl_intel
Source code (all arrays are of 1000 elements to ensure there is enough memory):
#include
#include
#include
int main(){
int n = 3;
// 1 2 3
// 2 4 5
// 3 5 7
double M[1000] = {1, 2, 3, 2, 4, 5, 3, 5, 7};
double a,b;
int i,j;
double accuracy = 1e-6;
int m;
double eigVal[1000];
double eigVect[1000];
int isuppz[1000];
double work[1000];
int iwork[1000];
int many = 1000;
int status = 0;
// First two work:
a = -100;
b = 100;
dsyevr("V", "V", "L", &n, M, &n, &a, &b, &i, &j, &accuracy, &m, eigVal, eigVect, &n, isuppz,
work, &many, iwork, &many, &status);
i = 1; j = 2;
dsyevr("V", "I", "L", &n, M, &n, &a, &b, &i, &j, &accuracy, &m, eigVal, eigVect, &n, isuppz,
// Second two make segfaults:
i = 1; j = 3;
dsyevr("V", "A", "L", &n, M, &n, &a, &b, &i, &j, &accuracy, &m, eigVal, eigVect, &n, isuppz,
int k;
for(k = 0; k < n; k ++){
printf("%f ", eigVal);
printf("\n");
return 0;
Gennady_F_Intel
Valery,
I guess you are trying to work on ia32 architecture, therefore you have to
1)setting L"/opt/intel/mkl/10.2.1.017/lib/32
and
2) using another linking line:
-Wl,--start-group -lmkl_intel -lmkl_intel_thread -lmkl_core -Wl,--end-group -liomp5 -lpthread
As a result your linking line should be like:
icc stuff.c -I"opt/intel/mkl/10.2.1.017/include/" -L"/opt/intel/mkl/10.2.1.017/lib/32" -Wl,--start-group -lmkl_intel -lmkl_intel_thread -lmkl_core -Wl,--end-group -liomp5 -lpthread
for more info how to link properly please refer to the KB article: http://software.intel.com/en-us/articles/intel-mkl-link-line-advisor/
--Gennady
valeriyfedotov
Thank you. But with this new linking line don't helped with segmentation fault.
Documentation says that when all eigenvalues are computed either by "A" parameter of by "I" parameter with i = 1 and j = n (this lines don't work), the routine references array isuppz, but it seems valid to me.
Gennady_F_Intel
Well. At the first glance all input parameters are correct.
Valery, can you check the problem when all arrays will be allocated dynamically.
For the reproducing the problem - what is the CPU type you are working on?
valeriyfedotov
My distro is Ubuntu 9.04, and processor Core 2 Quad Q9400.
I have done it with dynamical memory, but segfault remains. Also, it's intresting, when I uncomment bzero call, the program finishes normally.
#include
#include
#include
#include
int main(){
int n = 3;
// 1 2 3
// 2 4 5
// 3 5 7
double MM[1000] = {1, 2, 3, 2, 4, 5, 3, 5, 7};
double *M = (double *) malloc( sizeof(double) * 1000);
memcpy(M, MM, sizeof(double) * 9);
//bzero(M, sizeof(double) * 1000);
double a,b;
int i,j;
int m;
double *eigVal = (double *) malloc( sizeof(double) * 1000);
double *eigVect = (double *) malloc( sizeof(double) * 1000);
int *isuppz = (int *) malloc( sizeof(int) * 1000);
double *work = (double *) malloc( sizeof(double) * 1000);
int *iwork = (int *) malloc( sizeof(int) * 1000);
int many = 1000;
int status = 0;
// First two work:
a = -100;
b = 100;
i = 1; j = 2;
i = 1; j = 3;
int k;
printf("n");
return 0;
Gennady_F_Intel
See, the list of officially supported operating systems:
Ubuntu* 8.10 (IA-32 / Intel 64)
But I will check the problem and will back if any upadates.
Gennady_F_Intel
btw, originally i checked the problem on win32 and got the following output:
-0.600823 0.695387 11.905435
Do you have the similar results on ubuntu?
valeriyfedotov
No, I have got -0.247820, 0.338816, 11.908962. But I checked them with maxima and online solvers, they are correct.
For myself, I made a = -1e20 and b = 1e20 with "V" option, and make error in my subroutine if dsyevr doesn't find all values.
And I will try it in Ubuntu 8.10 this week.
Gennady_F_Intel
Quoting - valeriyfedotov
Valery,
the segmentaion problem was reproduced on RHEL 4, but no problem on win32. we will investigate the problem and will back to you asap.
--Gennady
Gennady_F_Intel
Valery,
--Gennady
Valery,
the problem you reported has been fixed in the latest MKL v.10.2 Update 2 available now.
You can download it from intel registratin center.
The version is shipped with Intel Compiler Proffesional Edition, version 11.1 for Linux ( build 056 ).
See the log i 've got running your test:
[root@XXXXX 555076]# ./fix.out
FIRST STEPS
SECOND STEPS
THIRD STEPS
4 STEPS
--Gennady
