7302 Discussions
Segmentation fault on declaring large array when mkl is linked
JaspervdK
I have a curious issue where a very simple (Fortran) program produces a segmentation fault if mkl is linked in the compiler. The program looks like,
program main
implicit none
  integer :: N_total
  complex*16, allocatable, dimension(:,:) :: Z_matrix_c
  N_total = 254571
  print*, 'before allocation'
  allocate(Z_matrix_c(N_total, N_total))
  print*, 'After Z_matrix_C allocation'
end program main
I know the complex*16 type declaration is not standard, but for legacy reasons I have to stick with it for now. The program allocates a very large (~ 1TB) array of double precision complex numbers. I am running this code on a cluster, where it works fine if I compile using ifort without any flags. If however I link the mkl library via -qmkl, the program segfaults upon entering the allocate statement. Curiously, if I increase the dimension of the array and make N_total say 270,000, the program also runs without issue.
Does anyone have an idea what may be happening here? I am using the 2021 versions of ifort and mkl.
Thanks!
VarshaS_Intel
Could you please let us know the OS details, and Cluster details you are using? Also, could you please provide us with the complete error you are getting while using the '-qmkl' option?
And also, we recommend you try the latest Intel MKL 2023.1.0 and let us know if your issue still persists.
Could you please let us know if you are using the '-qmkl' option and you did not face any error?
Thanks & Regards,
Varsha
Gennady_F_Intel
You could try to link this case against ILP64 libraries. Please check MKL Linker Adviser which libraries and compiler option you need to use.
VarshaS_Intel
Thanks & Regards,
Varsha
JaspervdK
Yes if I increase the dimension of the array the program runs fine even with -qmkl turned on.
JaspervdK
Thank you for your responses. After some digging it turns out that the problem is not with mkl itself, but rather with openmp. If the program is run with -mkl=sequential the issue disappears. Removing the -mkl flag altogether and adding the -fopenmp flag gives the same error.
Running Valgrind on the program returns an invalid read of size 8 in libiomp5.so as the reason for the segfault.
Unfortunately I can only link libraries installed on the cluster and I don't have a local machine with enough memory to test this program. I have tried linking the intel 2022 libraries, which is the latest installed version, but the same problem persists. The cluster runs on CentOS.
VarshaS_Intel
Thanks for your reply.
Could you please provide us with the complete command being used by you in running the code and let us know whether you are using ILP64 or LP64 libraries?
In addition, could you please let us know if you are able to run with Intel MKL (sequential as well as parallel) or if you are facing an issue with only OpenMP?
Also, please find the below link for using Intel Link Line Advisor which helps you with the link line commands to be provided while compiling your source.
https://www.intel.com/content/www/us/en/developer/tools/oneapi/onemkl-link-line-advisor.html
Thanks & Regards,
Varsha
JaspervdK
I compile the code as,
ifort code.F90 -i8 -qopenmp -o run
and then ./run. In this case I get the segmentation fault. You can see I run in ILP64, however turning off the -i8 flag actually does not matter for my error. If I compile with MKL instead,
ifort code.F90 -i8 -qmkl -o run
I get the same segmentation fault. If I compile in sequential mode,
ifort code.F90 -i8 -qmkl=sequential -o run
then the segmentation fault disappears.
Edit: I just noticed in the Link Line advisor that ILP64 requires linking -qmkl-ilp64. Maybe this is the issue, once I have access to the cluster again I will test this.
Edit 2: I now tried to compile as,
ifort code.F90 -i8 -qmkl-ilp64 -o run
but I still get the segmentation fault.
JaspervdK
Hello everyone,
Coincidentally, the intel compilers installed on the cluster were being updated to the new 2023 versions this week. It turns out that my allocation program does not run into any error when I use the new updated compilers, so it seems that my problem was solved in the latest update. Thanks a lot for the help!
VarshaS_Intel
It’s great to know that the issue has been resolved, in case you run into any other issues please feel free to create a new thread.
Have a Good Day!
Thanks & Regards,
Varsha
