7303 Discussions
Segmentation fault on declaring variable while using mkl for matrix vector multiplication
prakrati
Hello ,
I am trying to use mkl library to do matrix vector multiplication .When I am declaring a variable char t3 ,its giving segmentation fault
and when I am commenting it ,its running fine.Please help me debug this problem
I have bolded the line and wrote a comment on it to identify it.
The error that I am getting is as follows:Output :
./matrixVectorMultMKL2.o 10 10 1
Intializing.. size = 10
Performing multiplication 100 times..
Segmentation fault
Please help!!!
#include
#include
#include "mkl_cblas.h"
#include "mkl.h"
#include
#include
void DisplayVector(double *vector, int size)
int i;
for (i=0 ; i printf("%lf ",vector);
printf("\\n");
static inline unsigned long long getticks() {
unsigned int _hi,_lo;
__asm__ __volatile__("rdtsc":"=a"(_lo),"=d"(_hi));
return ((unsigned long long)_hi << 32) | _lo;
double getTimeInSeconds(long long ticks) {
// first calculate processor speed
long long t1,t2,processorSpeed;
double timeInSeconds;
t1 = getticks();
sleep(1);
t2 = getticks();
processorSpeed = t2 - t1;
// now calculate time
timeInSeconds = ((double) ticks) / ((double) processorSpeed);
//timeInSeconds = ((double) ticks) / CLOCKS_PER_SEC ;
return timeInSeconds;
int main(int argc,char *argv[])
int i, size = atoi(argv[1]);
//int i;
//int size = 3;
long long t1,t2;
double *matrix = (double *) mkl_malloc (size * size * sizeof(double),16);
double *vector = (double *) mkl_malloc (size * sizeof(double),16);
double *resultVector = (double *) mkl_malloc (size * sizeof(double),16);
char t3; //Segmentation fault is coming due to this line
printf("Intializing.. size = %d\\n",size);
for (i=0; i<(size*size); i++) {
//matrix = i+1;
matrix = 1;
for (i=0;i //vector = i+1;
vector = 1;
resultVector = 0;
void cblas_dgemv(const CBLAS_ORDER order,
const CBLAS_TRANSPOSE TransA, const MKL_INT M, const MKL_INT N,
const double alpha, const double *A, const MKL_INT lda,
const double *X, const MKL_INT incX, const double beta,
double *Y, const MKL_INT incY);
typedef enum {CblasRowMajor=101, CblasColMajor=102} CBLAS_ORDER;
typedef enum {CblasNoTrans=111, CblasTrans=112, CblasConjTrans=113} CBLAS_TRANSPOSE; */
mkl_set_num_threads ( 8 );
printf("Performing multiplication 100 times..\\n");
t1 = getticks();
//printf("t1 = %Ld\\n",t1);
for (i=0;i<100;i++) {
cblas_dgemv(CblasRowMajor, CblasNoTrans, size, size,1,matrix,size,vector,1,0,resultVector,1);
t2 = getticks();
//printf("Clock ticks required : %Ld\\n",t2 - t1);
//t = getTimeInSeconds(t2 - t1);
printf("Time for multiplication : %lf\\n",(getTimeInSeconds(t2 - t1)) / 100.0);
//printf("Result vector : ");
//DisplayVector(resultVector,size);
return 0;
mecej4
Which OS, C compiler, what version of MKL, and what were the compiler options used?
With Intel C 11.1.073 (IA32 or intel64) on SuSE Linux 11.3, the program, copied exactly from your post, can be compiled and run with no error messages when compiled with "icc -mkl -O ".
Gennady_F_Intel
Yes, more details will help to reproduce the problem.
I used to try with the latest Intel compiler v12 bundled ( aka Composer XE 2011). no problems..
--Gennady
prakrati
I am compiling it with GCC .The version of gcc and mkl is as follows:
GCC version used : gcc (GCC) 3.4.6 20060404 (Red Hat 3.4.6-8)
MKL version used : /app/intel/mkl/10.2.5.035
gcc matrixVectorMultMKL3.c -Wall -L $(MKLPATH) -I $(MKLINCLUDE) -lmkl_intel_ilp64 -lmkl_intel_thread -lmkl_core -liomp5 -lpthread -lm -o matrixVectorMultMKL3.o
When I compiled using your command ,it ran successfully so I am just confused why its not running with the previous command
Thanks and Regards
Prakrati
Gennady_F_Intel
That's very strange. Please try to remove all mkl routines calling. Will then be the same result?
mecej4
If you want to use ILP64 libraries, you probably have to tell GCC through suitable options that the default integer should be 64 bits.
