Segmentation fault with MKL PBLAS
mcastellana
Hello, I am trying to compile and run a sample code for a MKL PBLAS routine. I found the code herehttp://software.intel.com/en-us/articles/using-cluster-mkl-pblasscalapack-fortran-routine-in-your-c-program/ . You can find the code herepdgemv.c
I compile the code on a machine with Intel Mkl installed with the following command
mpicc -w -o pdgemv.o pdgemv.c -I/opt/intel/mkl/10.2.4.032/include -L/opt/intel/mkl/10.2.4.032/lib/em64t -lmkl_scalapack_lp64 -lmkl_blacs_intelmpi_lp64 -lmkl_intel_lp64 -lmkl_intel_thread -lmkl_core -liomp5 -lpthread
and get the warning
/opt/intel/Compiler/11.1/075/lib/intel64/libimf.so: warning: warning: feupdateenv is not implemented and will always fail
Then when I try to run I get segmentation fault:
[michelec@della3 pdgemv]$ mpirun -n 2 ./pdgemvlibrdmacm: couldn't read ABI version.
librdmacm: assuming: 4
CMA: unable to get RDMA device list
[[15168,1],0]: A high-performance Open MPI point-to-point messaging module
was unable to find any relevant network interfaces:
Module: OpenFabrics (openib)
Host: della3
Another transport will be used instead, although this may result in
lower performance.
[della3:03459] *** Process received signal ***
[della3:03459] Signal: Segmentation fault (11)
[della3:03459] Signal code: Address not mapped (1)
[della3:03459] Failing at address: 0x44000098
[della3:03458] *** Process received signal ***
[della3:03458] Signal: Segmentation fault (11)
[della3:03458] Signal code: Address not mapped (1)
[della3:03458] Failing at address: 0x44000098
[della3:03459] [ 0] /lib64/libpthread.so.0 [0x353900eb70]
[della3:03459] [ 1] /usr/local/openmpi/1.4.3/intel111/x86_64/lib64/libmpi.so.0(MPI_Comm_size+0x60) [0x2b821ceea410]
[della3:03459] [ 2] /opt/intel/Compiler/11.1/075/mkl/lib/em64t/libmkl_blacs_intelmpi_lp64.so(Cblacs_pinfo+0x93) [0x2b821aca1293]
[della3:03459] *** End of error message ***
[della3:03458] [ 0] /lib64/libpthread.so.0 [0x353900eb70]
[della3:03458] [ 1] /usr/local/openmpi/1.4.3/intel111/x86_64/lib64/libmpi.so.0(MPI_Comm_size+0x60) [0x2b206a7b6410]
[della3:03458] [ 2] /opt/intel/Compiler/11.1/075/mkl/lib/em64t/libmkl_blacs_intelmpi_lp64.so(Cblacs_pinfo+0x93) [0x2b206856d293]
[della3:03458] *** End of error message ***
mpirun noticed that process rank 1 with PID 3459 on node della3 exited on signal 11 (Segmentation fault).
[della3:03457] 1 more process has sent help message help-mpi-btl-base.txt / btl:no-nics
[della3:03457] Set MCA parameter "orte_base_help_aggregate" to 0 to see all help / error messages
Could you please help me?
Thanks!
Michele
Gennady_F_Intel
we have never met with this issue before - please see here may be this recomendation helps you.
mcastellana
Hello Gennady,
Thank you for your reply. Unfortunately the link didn't help: it seems to me that I have a different problem on running time. The segmentation fault occurs when "Cblacs_pinfo( &myrank_mpi, &nprocs_mpi ) ;" is called. Do you have any idea?
Thank you!
Michele
Jehandad_K_
Same problem and I cant figure it out !
Jehandad_K_
I found the problem, I was linking to intel mpi , when I linked to openmpi mkl the problem is solved !
