Serious error while using PARDISO
ratnani
hello,
i 'm trying to execute the sample code of PARDISO : pardiso_sym.f, and i've got this message:
OMP: Error #15: Initializing libguide.dylib, but found libiomp5.dylib already initialized.
OMP: Hint: This may cause performance degradation and correctness issues. Set environment variable KMP_DUPLICATE_LIB_OK=TRUE to ignore this problem and force the program to continue anyway. Please note that the use of KMP_DUPLICATE_LIB_OK is unsupported and using it may cause undefined behavior. For more information, please see http://www.intel.com/software/products/support/.
it seems like after the call ofpardisoinit, it charged iomp5 and so it cannot charge guide forpardiso call...
what is wrong?
thank you
my Makefile is :
OBJECTS = pardiso_sym.o \
F90 = ifort -c
LD = ifort
FFLAGS = -O3
F90FLAGS = -O3
LIBDIR = -L/Library/Frameworks/Intel_MKL.framework/Versions/10.0.5.025/lib/32 -L/opt/intel/Compiler/11.0/056/lib
INCLUDE = -I/Library/Frameworks/Intel_MKL.framework/Versions/10.0.5.025/include -I/opt/intel/Compiler/11.0/056/include
LIB = -lmkl_intel -lmkl_intel_thread -lmkl_solver -lmkl_core -lguide -liomp5 -lpthread
.f90.o:
$(F90) $(F90FLAGS) $(INCLUDE) $<
run: $(OBJECTS)
$(LD) $(F90FLAGS) $(OBJECTS) $(LIBDIR) $(LIB) -o $@
clean:
rm -f *.o *~ *.mod run
debug:
make F90FLAGS=-g FFLAGS=-g
Sergey_K_Intel1
If you are using MKL 10.0 on Mac32, the following linking line should be used
$ifort -w -I/Library/Frameworks/Intel_MKL.framework/Versions/10.0.5.025/include source/dss_sym_f.f -L/ibrary/Frameworks/Intel_MKL.framework/Versions/10.0.5.025/lib/32 -lmkl_solver -lmkl_intel -lmkl_intel_thread -lmkl_core -lguide -lpthread -lm
All the best
Sergey
Gennady_F_Intel
As an additional info please pay attention the next problem -you have to link only one of threading libraries either libguide or libiomp. We are encourage to use libiomp rather that libguide.
--Gennady
