Signature of v?Fdim, v?Fmax, ...
ingu
why is the second array of the functions v?Fdim, v?Fmax, v?Fmin etc. not constant?
The signature in the file mkl_vml_functions.h is:
_Mkl_Api(void, vdFdim, (const MKL_INT n, const double a[], double r1[], double r2[]))
_Mkl_Api(void, vdFmax, (const MKL_INT n, const double a[], double r1[], double r2[]))
_Mkl_Api(void, vdFmin, (const MKL_INT n, const double a[], double r1[], double r2[]))
I think it would be correct as:
_Mkl_Api(void, vdFdim, (const MKL_INT n, const double a[], const double b[], double r[]))
_Mkl_Api(void, vdFmax, (const MKL_INT n, const double a[], const double b[], double r[]))
_Mkl_Api(void, vdFmin, (const MKL_INT n, const double a[], const double b[], double r[]))
Kind regards
Gennady_F_Intel
Yes, you are right. the issue has been already raised and escalated. the fix will be available into on the next updates.
ingu
Tank you! Then I'm looking forward to the next update and I will use until then a const cast.
Gennady_F_Intel
yes, we will update this thread when the fix of the problem will be available.
Gennady_F_Intel
MKL v.2020 has been released and contains the fix of this problem either.
