7303 Discussions
Simple problem: Can't get 2d DFTs to compile in MKL 9.0. Help.
david_heim
Here's a trivial problem. What am I missing? Your suggestions would be greatly appreciated.
Dave
1d DFTs work fine. But when I try to compile the simplest, default 2d real DFT, I get the following error message from the compiler, which results from the DftiComputeForward statement.
"There is no matching specific function for this generic function reference. [DFTICOMPUTEFORWARD]"
My program is:
type(DFTI_DESCRIPTOR), pointer :: descriptor
real(8), dimension(1024,1024) :: a_in
integer, dimension(2) :: dfti_len
dfti_len(1)=16
dfti_len(2)=8
status=DftiCreateDescriptor(descriptor,DFTI_DOUBLE,DFTI_REAL,2,dfti_len)
status=DftiCommitDescriptor(descriptor)
status=DftiComputeForward(descriptor,a_in)
I compile/link with
ifort tst.f90 mkl_c.lib libguide40.lib
david_heim
O.K. I can now compile by looking at an example in the appendix of the reference manual.
