Solver settings in pardiso?
danielsue
Hi All,
My program have two solvers, solver A is based on Bi-CGSTAB acceleration that was developed by someone else before,  and another one (solver B) is pardiso. I found for Pardiso works fine as solver A for most of the time, but it run much slower than solver A if I use 1 or two threads.
The following settings is used in solver A:
maximum number of solver iterations:   100
solver residual tolerance: 1.0E-7
solver update tolerance: 1.0E-7.
I try to use this settings in pardiso as follows:
iparm(8) = 100      !numbers of iterative refinement steps
iparm(10) = 7       !perturbe the pivot elements with 1E-7
Is this correct? And how to set the residual tolerance?
Thanks and regards,
PS: other parameters
        iparm= 0
        iparm(1) = 1 ! no solver default
        iparm(2) = 3 ! fill-in reordering from METIS ,0-MIN DEGREE, 2-METIS, 3-OPENMP VERSION
        iparm(3) = 0 ! numbers of processors. Input the next call mkl_set_dynamic(0), mkl_set_num_threads(n);
        iparm(4) = 0 ! 0-no iterative-direct algorithm; 10*L+1 - CGS; 10*L+2 - CG; 10^-L is the tolerance.
        iparm(5) = 0 ! no user fill-in reducing permutation
        iparm(6) = 0 ! if == 0, the array of b is replaced with the solution x.
        iparm(7) = 0 ! not in use
        iparm(9) = 0 ! not in use
        iparm(11) = 1 ! use nonsymmetric permutation and scaling MPS
        iparm(12) = 0 ! not in use
        iparm(13) = 1 ! maximum weighted matching algorithm is switched-on (default for non-symmetric)
        iparm(14) = 0 ! Output: number of perturbed pivots
        iparm(15) = 0 ! not in use
        iparm(16) = 0 ! not in use
        iparm(17) = 0 ! not in use
        iparm(18) = -1 ! Output: number of nonzeros in the factor LU
        iparm(19) = -1 ! Output: Mflops for LU factorization
        iparm(20) = 0  ! Output: Numbers of CG Iterations
        iparm(27) = 0   !check matrix error, 0-without check, 1-check
        maxfct = 1
        mnum = 1
        nrhs = 1
        error = 0 ! initialize error flag
        msglvl = 0 ! print statistical information
        mtype = 11 ! real unsymmetric
Daniel
Gennady_F_Intel
What is the problem size?
Zhang_Z_Intel
Dainiel,
Would you please let us know how big the sparse system you're solving is?
Bi-CGSTAB is an iterative method, while PARDISO is a direct sparse solver. An iterative solver could be faster than a direct solver sometimes, especially when there is a good understanding of the initial conditions and/or a good preconditioner. Please share more details about your problem and your Bi-CGSTAB solver such that we can provide more meaningful answer.
