Some subroutines of lapack in mkl gives Segmentation fault for matrix dimension larger than 1020
Zhang__Simon
OS: Ubuntu 18.04.2 server, kernel 4.15.0-50-generic. MKL provided by intel parallel studio xe 2019.3.
The C code reproducing the error
#include <stdlib.h>
#include <stdio.h>
#include <mkl.h>
#define N 1021
int main(){
printf("begin main\n");
double m,a[N*N];
lapack_int n1=N, n2=N;
for(size_t i=0;i<N*N;i++){
if(i%(N+1)==0){
a=(double) rand()/RAND_MAX;
else {a=0;}
lapack_int info;
printf("begin lapack\n");
info = LAPACKE_dsyevd(LAPACK_ROW_MAJOR, 'V','U', n1, a, n2, m);
printf("%d: end lapack\n", info);
return 0;
This code gave correct results for matrix smaller than 1020*1020, while gave Segmentation fault when N>1020. The error persists for icc, gcc, linking options as simple as -mkl for icc or full linking and compiling options as advised by linking advisor. dsteqr routine seems have similar issues.
I am new to directly using lower level routines in MKL, so there may also be some problems in my code above. Though it works well for smaller matrix.
Thanks in advance.
Zhang__Simon
I have solved the issue. It is because the default soft limit on stack size is too small for declaring large array in main function(stack). Just try `ulimit -s unlimited`, everything works fine then.
