7303 Discussions
Sparse Hermitian matrix and vector multiplication
flygaoonly
In MKL, are there functions or subroutines that can performcomplex sparse Hermitian matrix and vector multiplication? I only saw the one for sparse symmetrical matrix.
Sergey_K_Intel1
MKL has got sparse matrix-vector multiply several routines for Hermitian matrices and one of them is
call mkl_zcsrmv(transa, m, k, alpha, matdescra, val, indx, pntrb, pntre, x, beta, y)
In the case of Hermitian matrix, the first element of the parameter
matdescra
CHARACTER. Array of six elements, specifies properties of the matrix used for operation.
must be H or h.
All the best
Sergey
flygaoonly
I got it. Thank you very much.
flygaoonly
Another thing. If I want to compile my program (bdg.f90 which uses mkl_ccoomv) on a Linux system, can I use the following command:
ifort bdg.f90 -L /opt/intel/mkl/10.0.1.014/lib/em64t -I /opt/intel/mkl/10.0.1.014/include -lmkl_intel -lmkl_intel_thread -lmkl_core -liomp5 -lpthread
If not, what command should I use? Thank you.
flygaoonly
After reading the User's Guide, I use the following command to compile my program bdg.f90, in which I called mkl_ccoomv.
ifort bdg.f90 -L/opt/intel/mkl/10.0.1.014/lib/em64t -I/opt/intel/mkl/10.0.1.014/include -Wl,--start-group /opt/intel/mkl/10.0.1.014/lib/em64t/libmkl_em64t.a /opt/intel/mkl/10.0.1.014/lib/em64t/libmkl_blas95.a /opt/intel/mkl/10.0.1.014/lib/em64t/libmkl_intel_lp64.a /opt/intel/mkl/10.0.1.014/lib/em64t/libmkl_intel_thread.a /opt/intel/mkl/10.0.1.014/lib/em64t/libmkl_core.a -Wl,--end-group -lmkl -lguide -lpthread
But I still got the following error:
undefined reference to 'mkl_ccoomv'
What's wrong with it, can you give me some advice? Thanks.
barragan_villanueva_
Valued Contributor I
Please use Intel MKL Link Line Advisor
E.g., for MKL 10.0 it should be:
-lmkl_blas95_lp64 $(MKLROOT)/lib/em64t/libmkl_solver_lp64.a -Wl,--start-group $(MKLROOT)/lib/em64t/libmkl_intel_lp64.a $(MKLROOT)/lib/em64t/libmkl_intel_thread.a $(MKLROOT)/lib/em64t/libmkl_core.a -Wl,--end-group -openmp -lpthread
flygaoonly
Thank you for your advice. However, as you suggested, I use the following command:
ifort bdg.f90 -lmkl_blas95_lp64 /opt/intel/mkl/10.0.1.014/lib/em64t/libmkl_solver_lp64.a -Wl,--start-group /opt/intel/mkl/10.0.1.014/lib/em64t/libmkl_intel_lp64.a /opt/intel/mkl/10.0.1.014/lib/em64t/libmkl_intel_thread.a /opt/intel/mkl/10.0.1.014/lib/em64t/libmkl_core.a -Wl,--end-group -openmp -lpthread
There is an error:
ld: cannot find -lmkl_blas95_lp64
The same thing happans if I use
ifort bdg.f90 -I/opt/intel/include/em64t/lp64 -lmkl_blas95_lp64 /opt/intel/mkl/10.0.1.014/lib/em64t/libmkl_solver_lp64.a -Wl,--start-group /opt/intel/mkl/10.0.1.014/lib/em64t/libmkl_intel_lp64.a /opt/intel/mkl/10.0.1.014/lib/em64t/libmkl_intel_thread.a /opt/intel/mkl/10.0.1.014/lib/em64t/libmkl_core.a -Wl,--end-group -openmp -lpthread
So what's the problem?
Sorry,
libmkl_blas95_lp64.a was introduced in MKL 10.2 only but you use MKL 10.0. MKL Link Advisor is to be fixed.
So please try to link your program without it.
flygaoonly
Without it, I then use
ifort bdg.f90 /opt/intel/mkl/10.0.1.014/lib/em64t/libmkl_solver_lp64.a -Wl,--start-group /opt/intel/mkl/10.0.1.014/lib/em64t/libmkl_intel_lp64.a /opt/intel/mkl/10.0.1.014/lib/em64t/libmkl_intel_thread.a /opt/intel/mkl/10.0.1.014/lib/em64t/libmkl_core.a -Wl,--end-group -openmp -lpthread
but still got "undefined reference to mkl_ccoomv".
This function was introduced in MKL 10.1 and therefore is missing in MKL 10.0
flygaoonly
So in this case, is there any other sparse matrix vector multiplication subroutine I can use?
Customer__Intel4
Hi
In case of using this function with hermitian or symmetric matrix, do we store only the upper / lower triangle or the whole matrix ?
Konstantin_A_Intel
Quoting tarek.e
Hi
Yes, sure.
