7303 Discussions
Sparse Matrix Structure leads Zero Pivot Error
diogoneto
Hi all,
I am using the DSS from MKL to solve the linear system of equations Ax=b, for which the resulting matrix A is sparse and not symmetric, but its structure is symmetric.
Concerning the options, I am using MKL_DSS_SYMMETRIC_STRUCTURE in the definition of the structure and MKL_DSS_INDEFINITE in the factorization.
 I am using the following example (15*15 matrix in attachment) to try and solve a system considering that the matrix A is sparse. Unfortunately, the DSS solver gives an error of “MKL-DSS-DSS-Error, Zero Pivot detected”, but the matrix is non-singular. The determinant of the matrix is about -3.1e+62 (calculated in excel) and I get the solution both in excel and matlab.
When I switch the definition of the matrix structure for MKL_DSS_NON_SYMMETRIC, I get the correct solution. I don’t understand why!
In order to understand this problem I create a new subroutine. Using the initial definition of matrix structure, I give all elements of A as non-zero (dense matrix), I am not take advantage of the sparse matrix. With this structure, DSS solver gives the correct solution.
Someone can help me why I cannot use the MKL_DSS_SYMMETRIC_STRUCTURE definition in the sparse matrix structure.
Both subroutines are in attachment.
Thank you.
Diogo
Gennady_F_Intel
thanks for the case, it looks like the issue for DSS. we will   check the problem on our side and let you know the results soon.
Gennady_F_Intel
Hi Diogo,
Yes, we confirmed that this is the bug and the cause of the problem has been found. How important this issue is for you? Can you use the MKL_DSS_NON_SYMMETRIC case as a temporarily workaroud? we expect no performance degradation in that case.
-Gennady
diogoneto
Hi Gennady,
Thank you for your quick response. I have not problem to use the option MKL_DSS_NON_SYMMETRIC and I check yesterday that the  performance is not affected with a simple problem.
Diogo
Gennady_F_Intel
well, we will let you know when the original problem would be fixed and which next update. thanks, Gennady
Gennady_F_Intel
Diogo,
please check the latest update  1 ( MKL 11.1 Update 1) where the fix of the problem has been provided. Pls let us know if the problem is still there.
