7303 Discussions
Sparse PARDISO_64 solver and weird solutions
Jason_d_
Hi there,
We are encountering inconsistent behaviour with the sparse PARDISO_64 solver.
We are trying to solve a linear system, which corresponds to the stationary distribution of a discrete-time Markov chain. The transition matrix can be generated for small or large state spaces. The application requires a solution for a large state space (very sparse transition matrix); I include code for a small state space (not very sparse) that reproduces the problem we're encountering. Oddly, when the transition matrix is < 101 in size (ie., 101 x 101), this code produces correct results. However, with matrix size >=101, it gives non-sense results including negative values.
I've run this same matrix in R, using its default dense linear solver, and it solves the system just fine and returns a vector that sums to one with all entries positive.
Can someone let us know if this is a bug? Any suggestions?
Thanks very much,
- Jason
To compile the example:
icc -o test ./tester.c -DMKL_ILP64 -std=c99 -g -m64 -fopenmp -lmkl_intel_ilp64 -lmkl_core -liomp5 -lmkl_intel_thread -lpthread -lmkl_avx -lmkl_vml_avx -lm -liomp5 -ldl -lrt
Output:
$ ./test
=== PARDISO: solving a real nonsymmetric system ===
0-based array is turned ON
PARDISO double precision computation is turned ON
Parallel METIS algorithm at reorder step is turned ON
Scaling is turned ON
Matching is turned ON
Summary: ( reordering phase )
Times:
Time spent in calculations of symmetric matrix portrait (fulladj): 0.000282 s
Time spent in reordering of the initial matrix (reorder)         : 0.002224 s
Time spent in symbolic factorization (symbfct)                   : 0.000373 s
Time spent in data preparations for factorization (parlist)      : 0.000009 s
Time spent in allocation of internal data structures (malloc)    : 0.001029 s
Time spent in additional calculations                            : 0.000441 s
Total time spent                                                 : 0.004357 s
Statistics:
Parallel Direct Factorization is running on 1 OpenMP
< Linear system Ax = b >
             number of equations:           101
             number of non-zeros in A:      7649
             number of non-zeros in A (%): 74.982845
             number of right-hand sides:    1
< Factors L and U >
             number of columns for each panel: 128
             number of independent subgraphs:  0
             number of supernodes:                    9
             size of largest supernode:               73
             number of non-zeros in L:                7376
             number of non-zeros in U:                1599
             number of non-zeros in L+U:              8975
ooc_max_core_size got from config file=100000
ooc_max_swap_size got from config file=10000
ooc_path          got from config file=/tmp
ooc_keep_file     got from config file=1
=== PARDISO is running in In-Core mode, because iparam(60)=1 and there is enough RAM for In-Core ===
Percentage of computed non-zeros for LL^T factorization
 1 %  2 %  3 %  4 %  5 %  27 %  100 %
Single-level factorization algorithm is turned ON
Summary: ( factorization phase )
Times:
Time spent in copying matrix to internal data structure (A to LU): 0.000000 s
Time spent in factorization step (numfct)                        : 0.002051 s
Time spent in allocation of internal data structures (malloc)    : 0.000871 s
Time spent in additional calculations                            : 0.000008 s
Total time spent                                                 : 0.002930 s
Statistics:
< Factors L and U >
             gflop   for the numerical factorization: 0.000497
             gflop/s for the numerical factorization: 0.242160
Summary: ( starting phase is factorization, ending phase is solution )
Times:
Time spent in factorization step (numfct)                        : 0.000978 s
Time spent in direct solver at solve step (solve)                : 0.000152 s
Time spent in allocation of internal data structures (malloc)    : 0.000225 s
Time spent in additional calculations                            : 0.000010 s
Total time spent                                                 : 0.001365 s
Statistics:
< Linear system Ax = b > < transpose >
< Factors L and U >
             gflop/s for the numerical factorization: 0.507876
Solution complete
0    0.999995193211361765861511230469
1    0.000032578641480540682096034288
2    -0.001657514998954390250673895935
3    0.033771150451229914324358105659
4    -0.461805824206749093718826770782
5    4.749899498253853380447253584862
6    -38.771420601724457810632884502411
7    259.248515126662823604419827461243
8    -1449.667206926258586463518440723419
9    6874.129777303653099806979298591614
10    -27898.278384158944390946999192237854
11    97440.861928413447458297014236450195
12    -293504.794066837057471275329589843750
13    761189.228222305420786142349243164062
14    -1688760.591960122343152761459350585938
15    3160374.134989297483116388320922851562
16    -4847723.865611193701624870300292968750
17    5708551.324229651130735874176025390625
18    -4176587.558768271468579769134521484375
19    -647335.411046688444912433624267578125
20    7123983.262770898640155792236328125000
21    -10372849.399064248427748680114746093750
22    5097756.375352034345269203186035156250
23    8368298.486144787631928920745849609375
24    -20094661.334219779819250106811523437500
25    15530267.332568019628524780273437500000
26    10869635.995811181142926216125488281250
27    -45071205.791867606341838836669921875000
28    59302210.260278038680553436279296875000
29    -32906353.391984485089778900146484375000
30    -29776674.515638992190361022949218750000
31    100146018.075395077466964721679687500000
32    -142138732.192305266857147216796875000000
33    132670794.247007787227630615234375000000
34    -77887861.591384351253509521484375000000
35    16047679.964387292042374610900878906250
36    8486771.549898184835910797119140625000
37    8432116.450060281902551651000976562500
38    -19044070.376644946634769439697265625000
39    -14876318.802595624700188636779785156250
40    53651210.152546934783458709716796875000
41    -18599756.443840526044368743896484375000
42    -83578205.019382655620574951171875000000
43    132441139.780909150838851928710937500000
44    -44723190.570743650197982788085937500000
45    -90119098.758960306644439697265625000000
46    112308026.259973496198654174804687500000
47    -15883799.202348483726382255554199218750
48    -37476735.814083844423294067382812500000
49    -42720512.310896500945091247558593750000
50    136331725.799720644950866699218750000000
51    -94694026.197748795151710510253906250000
52    -24969756.509624961763620376586914062500
53    36123495.129054218530654907226562500000
54    95371312.336257725954055786132812500000
55    -187649724.744519829750061035156250000000
56    99580546.284361138939857482910156250000
57    61281447.953638210892677307128906250000
58    -75682784.307738944888114929199218750000
59    -94990590.347380638122558593750000000000
60    249469815.636476099491119384765625000000
61    -185170645.040623068809509277343750000000
62    -69561311.618086069822311401367187500000
63    291469651.987545907497406005859375000000
64    -296767916.465866982936859130859375000000
65    107424872.212943851947784423828125000000
66    100278309.586056604981422424316406250000
67    -174662996.371612936258316040039062500000
68    105230287.342239096760749816894531250000
69    10815686.119901048019528388977050781250
70    -81002433.999335929751396179199218750000
71    86416125.554535329341888427734375000000
72    -62056087.853065535426139831542968750000
73    40542349.147022008895874023437500000000
74    -26163544.408309187740087509155273437500
75    10472964.159998646005988121032714843750
76    5665027.077539607882499694824218750000
77    -11247268.616148518398404121398925781250
78    -535759.321254136040806770324707031250
79    23669191.133846260607242584228515625000
80    -44661930.400523439049720764160156250000
81    53449912.937561854720115661621093750000
82    -48916840.807791873812675476074218750000
83    36568077.467748269438743591308593750000
84    -23051005.968265801668167114257812500000
85    12468528.466729646548628807067871093750
86    -5845339.524531649425625801086425781250
87    2387800.565653024241328239440917968750
88    -851709.236374233034439384937286376953
89    265137.756044438341632485389709472656
90    -71829.217305896498146466910839080811
91    16846.539484900742536410689353942871
92    -3393.713058615743648260831832885742
93    580.705784613051491760415956377983
94    -83.109681426136376103386282920837
95    9.736892611661156493596536165569
96    -0.905525373004574585245052276150
97    0.063834158911049598827958106995
98    -0.003165205991651388536811673191
99    0.000096134640968314257489582553
100    -0.000008968170732259750366210938
mecej4
I think that you have to debug your code and establish (i) if the matrix and right-hand-side vector are being formed with correct values and (ii) if the code calls Pardiso correctly.
I conducted an independent check using code that I had on hand. The attached zip contains three files -- (i) cnvmat.c, which outputs your matrix data in the form expected by (ii) the Fortran program unsymcsr.f90, and (iii) the converted file csv.mat.
The solution checks out. I suspect that your matrix is not correct in at least the following aspect: you make each of the elements in the last column of the matrix equal 1.0. If you want the sum of the solution values to equal 1.0, as you said, it is the elements of the last row of the matrix that should each equal 1.0. (Please check these statements. I have not studied your program in depth).
Zhen_Z_Intel
Dear customer,
I checked with your code and data file, seems no problem with your setting of pardiso. I tried to use csrgemv to calculate y=Ax to verify your result. Seems there's indeed a problem. We will investigate on it. Thanks.
Fiona
mecej4
Jason_d_
Thanks mecej4. You were right. The matrix was malformed. Once fixed, the code works
mecej4
It is nice to hear that you have fixed the issue, but I still have one doubt that I do not see the answer to: what is special about a square matrix of size 101, and how could you have obtained correct results with matrices smaller than that despite having 1-s on the last column instead of the last row?
