Specific Stiff ODE Problem
ted_kord
Hi all
I have a set of five coupled ODEs.
Each ode has one or more additional parameters.
Each parameter however, is a function of ,say, voltage.
So, for example:
ODE 1: RHS = f(t,y) = a * exp(......)
where the value of 'a' is dependent on a specific voltage, i.e, a(voltage).
I need to (must) solve the ODEs and obtain the current solution at each time step!
Question 1 : How can I supply at each time step a different voltage to calculate the parameter 'a'?
Question 2a: How can I obtain the solution at each time step ?
Question 2b: Perform some operation(s) with the current solution at that time step and then advance to the next time step?
I've tried several stiff ODE algorithms but no luck. I'd now like to use the Intel ODE library to solve this problem.
Any pointers/help in how to do this is appreciated.
Ted Kord
Sergey_G_Intel
Hi Ted,
Ive estimated eigenvalues of your problem using Intel MKL LAPACK. As a result, for resistance=-40.8 Ive got that the eigenvalues of your system are:
0: -9.32634+0i
1: -0.0462603+6.01633i
2: -0.0462603+-6.01633i
3: -1.06398e-013+0i
4: -6965.59+0i
As you can see, the real parts of all eigenvalues are negative. This means that the system has bounded solution. When I set resistance to -40.9, Ive got the following set of eigenvalues:
0: -9.2891+0i
1: 0.0431913+5.99626i
2: 0.0431913+-5.99626i
3: 5.6765e-013+0i
4: -6975.47+0i
As you can see, there are 2 eigenvalues with positive real parts. Asymptotically, the solution of the system would behave as exp(0.043*t), which is unbounded function when t grows. This is what you see when trying to solve the system with resistance <-40.8 with our ODE solver.
It looks that I cannot help you more with your ODE system as it is just unstable for certainvalues of parameter "resistance". Sorry, if this does not help you much
-Sergey G
Sergey_G_Intel
Hi Ted,
Please find the code below:
#include
#include
#include
#include "intel_ode.h"
#include "mkl.h"
using namespace std;
double resistance=-40.8;
double a = 36.367689741213006 * exp(0.055398582982867296 * resistance);
double b = 0.28447798136999997 * exp(-0.02159796106832056 * resistance);
double c = 176.39278458673601 * exp(0.055398582982867296 * resistance);
double d = -4.6565444211489995 * exp(-0.036607982538678523 * resistance);
double e = 1334.3934962347917 * exp(-0.030581515065542283 * resistance);
double f = 5003.889182919519 * exp(0.018865463394165619 * resistance);
double g = e*b/f;
void rhs (int *n, double *t, double *y, double *rhs) {
rhs[0] = (d * y[1])-(c * y[0]);
rhs[1] = -((d + 2.172) * y[1])+(c * y[0])+(1.077 * y[2]);
rhs[2] = -((1.077 + a + a) * y[2]) + (2.172 * y[1]) + (b * y[3]) + (g * y[4]);
rhs[3] = -((b + f) * y[3]) + (a * y[2]) + (e * y[4]);
rhs[4] = -((g + e) * y[4]) + (a * y[2]) + (f * y[3]);
int main(){
int ipar[128];
int n=5, ierr;
int kd[5];
double t=0.0, t_end=6100.0, ti=0.02;
double y[5], h=1.0e-7, hm=1.0e-14, ep=1.0e-3, tr=1.0e-3, *dpar;
void *jacmat=NULL;//dummy at the moment
double mat[25];
cout<<"Starting computations...n";
cout<<<" "<<<" "<<<" "<<<" "<<<" "<<<" "<<<"n";
for (int i=0;i<128;i++) ipar=0;
mat[0]=-c;
mat[1]=c;
mat[2]=0.0;
mat[3]=0.0;
mat[4]=0.0;
mat[5]=d;
mat[6]=-2.172-d;
mat[7]=2.172;
mat[8]=0.0;
mat[9]=0.0;
mat[10]=0.0;
mat[11]=1.077;
mat[12]=-2*a-1.077;
mat[13]=a;
mat[14]=a;
mat[15]=0.0;
mat[16]=0.0;
mat[17]=b;
mat[18]=-b-f;
mat[19]=f;
mat[20]=0.0;
mat[21]=0.0;
mat[22]=g;
mat[23]=e...
from ia32 folder for my 32-bit laptop).
-Sergey G
ted_kord
Hi Sergey
I'll add it to my toolbox. Thank you.
Ted
Sergey_G_Intel
Good luck, Ted!
-Sergey G
