Static vs. dynamic vector input
vincent_ferri
I am having an issue with dynamic input arguements to the following functions;
LAPACKE_dgelss();
dgetrf();dgetri();
ippmInvert_m_64f();
When the input vector is static A[10 * 10] = {...}; the output is correct namely A inverse.  If the same data values are read into a dynamic vector the output is incorrect. Why am I getting this anomally?
Vince
vincent_ferri
c_vector is the file name, what is wrong with you, it contains matrices which intel calls vectors ( everything in MKL seems to use vectors). The file contains three matrices a,b,c.
a is [4 x 10] and b is [10X4] and c should be [10 X 10] not a scalar.
What I now is Matlab computes the c matrix and inv(c) computs the correct coeff.
SergeyKostrov
Valued Contributor II
>>...c_vector is the file name, what is wrong with you,.. Vicent, please watch your language.
mecej4
Presumably, you want c to match b X a, rather than a X b, which would be a 4 X 4 matrix. Perhaps, you obtained the values of the elements of matrix c using Matlab or some such tool, but printed out the values with insufficient precision. Since a and b contain three-digit numbers, you need at least six digits for the elements of c. In the file, however, you only display three significant digits for  these. Therefore, you should expect errors of as much as 500 in the elements of matrix c in the file.
The solution is quite simple. Set Matlab (or other utility) to print enough significant digits before you compare.
