7302 Discussions
Storing Tri-diagonal matrix in coo or csr format.
elmeliegy__abdelrahm
Is there any function/method to store the tridiagonal matrix in csr or coo format.
mecej4
This is so trivial that there is no need to write a routine to do it. For a matrix of size n, all you need to do is to set
     IA = [1, 3, 6, 9, ..., 3n-3; 3n-1]
     JA = [1,2,  3,4,5,  6,7,8,  ,...,3n-3, 3n-2]
and A to the 3n-2 values, arranged by rows.
Furthermore, why do you want to use the more general CSR representation for a tridiagonal matrix?
Thank you
I am going to assemble the tridiagonal matrix into csr/coo format and then use PARDISO linear solver routines.
mecej4
Why do that? That would be wasted effort, since the "Thomas Algorithm" for solving tridiagonal equations can be coded in 10 to 20 lines of code.
I am upgrading an old FE code and i am going to set the solver as PARDISO. So, i need to convert all assembly format to the csr format.
