Strange partial pivoting of LAPACKE_dgetrf
yang__xiaolin
I'm using LAPACKE_dgetrf to compute the LU factorization of square matrices in double precision. The matrix is in column major. Here is what I am doing. The environment is MKL 2018 Update 3 for Windows + Visual studio 2017.
for(...)
lapack_int m = dim;    //dim is around 40 to 80
double * A = (double*)mkl_malloc(m * m * sizeof(double), 64);
memcpy(A, source, m * m * sizeof(double));
lapack_int * ipiv = (lapack_int*)mkl_malloc(m * sizeof(lapack_int), 64);
lapack_int info = 0;
int mat_layout = LAPACK_COL_MAJOR;
for(int k = 0; k < m; k++)    //flush ipiv before calling dgetrf
    ipiv = -1;
info = LAPACKE_dgetrf(mat_layout, m, m, A, m, ipiv);
if(info != 0)
{clean up memory;
    break;}
I checked the info that was returned by LAPACKE_dgetrf and it was always 0. However, I found out I got duplicate items in ipiv array after each dgetrf call.
I mean I got ipiv == ipiv  (0 < i , j < m), which doesn't make sense for partial pivoting. I also flushed the ipiv array before calling dgetrf.
What is the possible reason for getting duplicate values in partial pivoting array?
Thank you.
Ying_H_Intel
Hi Xiaolin,
could you please attach one test case to show the problem?
​for example, below
#include <stdio.h>
#include <stdlib.h>
#include <memory.h>
#include <mkl.h>
int main(void)
 int len = 198;
 char buf[198];
 mkl_get_version_string(buf, len);
 printf("%s\n", buf);
 printf("\n");
 lapack_int m = 3; //dim is around 40 to 80
 double  A[9] = { 0, 5, 5, 2, 9, 0,6, 8, 8 };
 //double * A = (double*)mkl_malloc(m * m * sizeof(double), 64);
 //memcpy(A, source, m * m * sizeof(double));
 for (int k = 0; k < m; k++)  //flush ipiv before calling dgetrf
  ipiv = -1;
 if (info != 0)
  printf("info error %d", info);
  //break;
printf("\nLU_A\n");
for (int i = 0; i <m; i++) {
 for (int j = 0; j < m; j++) {
  printf("%f ", A[i + j * 3]);
 printf("\n");
printf("ipiv:\n");
for (int i = 0; i < m; i++) {
 printf("%d ", ipiv);
return 0;
i did a quick test with MKL 2018 u3.  the result looks fine with small size input
Intel(R) Math Kernel Library Version 2018.0.3 Product Build 20180406 for Intel(R) 64 architecture applications
LU_A
5.000000 9.000000 8.000000
1.000000 -9.000000 0.000000
0.000000 -0.222222 6.000000
ipiv:
2 3 3 Press any key to continue . . .
Ying
https://software.intel.com/en-us/articles/intel-math-kernel-library-intel-mkl-2018-bug-fixes-list
Kirana_B_Intel
The ipiv array is an array that lists row interchanges, it is not a true pivot vector. So if you see an ipiv array for a 3x3 case that looks like [2,2,2], that means that row 1 was interchanged with row 2, then row 2 (which is the original row 1) stayed the same, then row 3 was interchanged with row 2 (which was the original row 1).
You get find more information about this in the description for ipiv in the getrf documentation https://software.intel.com/en-us/mkl-developer-reference-c-getrf. The routines getrs and getri are provided to work with pivot arrays of this form.
yang__xiaolin
Thank you.
