TR solver question
Andrew_Smith
Valued Contributor I
When the solver returns RCI_Request = 2 to calculate the Jacobian, can I assume that x has not changed since the previous calculation of the function value?
It would be a great performance boost if I could because my calculations of function value and jacobian are not seperable and I could just use my stored jacobian.
Jing_Xu
I looks reasonable when x doesn't change and RCI_Request = 2 following right after 1.
We will communicate with engineer team.
Thank you.
