Tensor multiplication using MKL
radjaradja
Is it possible to perform a multidimensional array multiplication using Intel MKL? If it is, could you please provide the name of the function I should use or a simple example?
Thank you
Khang_N_Intel
Hi Radjaradja,
Thank you for posting!
I believe that Intel(R) MKL doesn't directly support tensor operations.  You might want to look into TBLIS at: https://github.com/devinamatthews/tblis/wiki
Khang
