The command "..." exited with code 1
hajdul__patryk
I recently downloaded the mkl and tried to test it using a simple code.  When I build it however, I get a message saying: the command … exited with code 1. Anyone know how to fix it?
UPDATE: I uninstalled the cluster edition and installed the other edition and it's working now.
Gennady_F_Intel
Could you show how did you build and run this code? could you give an example of this case?
hajdul__patryk
I don't know much about that kind of stuff unfortunately. I wouldn't remember. Fortunately though I am not experiencing the issue anymore.
