The sample program doesn't work.
siinii
I made a code that looked a sample code.
The small size(100X40) was worked. but The big size(2560X3072) was not worked.
Are there bugs in a code?
Here are sample code that I edited.
void BoolLib::Run4()//
int Level_limit =5;
int i,j;
_complex** x;
float** y;
y = new float* [3074];
for(i=0; i<3074; i++) y = new float[2562];
x = new _complex* [3072];
for(i=0; i<3072; i++) x = new _complex[2560];
int Height_f = 3072;
int Widtht_f = 2560;
DFTI_DESCRIPTOR_HANDLE my_desc1_handle;
DFTI_DESCRIPTOR_HANDLE my_desc2_handle;
MKL_LONG status;
MKL_LONG l[2];
l[0] = Height_f, l[1] = Widtht_f;
for(i=0; i
for(j=0; j
x.x = 0.0;
x.y = 0.0;
for(i=0; i<(Height_f+2); i++)
for(j=0; j<(Widtht_f+2); j++)
y = 0.0;
for(i=0; i
for(j=0; j
if((j%10) == 0)
x.x = 200.0;
float src;
status = DftiCreateDescriptor( &my_desc1_handle, DFTI_SINGLE, DFTI_COMPLEX, 1, Height_f);
status = DftiCreateDescriptor( &my_desc2_handle, DFTI_SINGLE, DFTI_COMPLEX, 1, Widtht_f);
l[0] = 0, l[1] = Widtht_f;
status = DftiSetValue(my_desc1_handle, DFTI_NUMBER_OF_TRANSFORMS, Widtht_f);
status = DftiSetValue(my_desc1_handle, DFTI_INPUT_DISTANCE, 1);
status = DftiSetValue(my_desc1_handle, DFTI_OUTPUT_DISTANCE, 1);
status = DftiSetValue(my_desc1_handle, DFTI_INPUT_STRIDES, l);
status = DftiSetValue(my_desc1_handle, DFTI_OUTPUT_STRIDES, l);
status = DftiCommitDescriptor( my_desc1_handle);
status = DftiComputeForward( my_desc1_handle, x);
l[0] = 0, l[1] = Height_f;
status = DftiSetValue(my_desc2_handle, DFTI_NUMBER_OF_TRANSFORMS, Height_f);
status = DftiSetValue(my_desc1_handle, DFTI_INPUT_DISTANCE, Widtht_f);
status = DftiSetValue(my_desc1_handle, DFTI_OUTPUT_DISTANCE, Widtht_f);
status = DftiCommitDescriptor( my_desc2_handle);
status = DftiComputeForward( my_desc2_handle, x);
status = DftiFreeDescriptor( &my_desc1_handle);
status = DftiFreeDescriptor( &my_desc2_handle);
delete [] x;
delete [] y;
Dmitry_B_Intel
Hi siinii,
You probably did the small size on a static array, defined as x[100][40]. The way the dynamic array is arranged in your exampleis incorrect and it demonstrates typical mistake. For static array '_complex x' expression 'x' has type '_complex *' whereas for dynamic array that one would use with double-subscript notation 'x' the type of 'x' is '_complex**' that is pointer to pointers. In other words, in this example when you call DftiComputeForward(..., x) the input data to the FFT routine is pointers, not the complex numbers!
I'd suggest you to refrain from the practice of using double-subscript notation for dynamic arrays, and adoptthe following usage instead:
const int ROWS=3072, COLS=2560;
const int ROWSIZE=COLS, COLSIZE=ROWS;
_complex *x = new _complex[ROWS*COLS];
#define x(r,c) x[*ROWSIZE+(c)] /* explicit row-major indexing */
memset(x,0,sizeof(x[0])*ROWS*COLS); /* zero fill initialization */
for (r=0;r
The rest of this reply is duplicating your example in the above terms.
DftiCreateDescriptor(rowfft,DFTI_SINGLE,DFTI_COMPLEX,1,ROWSIZE); /* stride 1 by default */
DftiSetValue(rowfft,DFTI_NUMBER_OF_TRANSFORMS,(MKL_LONG)ROWS);
DftiSetValue(rowfft,DFTI_INPUT_DISTANCE,(MKL_LONG)ROWSIZE);
DftiSetValue(rowfft,DFTI_OUTPUT_DISTANCE,(MKL_LONG)ROWSIZE);
DftiCreateDescriptor(colfft,DFTI_SINGLE,DFTI_COMPLEX,1,COLSIZE); /* will setstrides */
MKL_LONG colfft_strides[] = { 0,ROWSIZE };
DftiSetValue(colfft,DFTI_INPUT_STRIDES,colfft_strides);
DftiSetValue(colfft,DFTI_OUTPUT_STRIDES,colfft_strides);
DftiSetValue(colfft,DFTI_NUMBER_OF_TRANSFORMS,(MKL_LONG)COLS);
DftiSetValue(colfft,DFTI_INPUT_DISTANCE,(MKL_LONG)1);
DftiSetValue(colfft,DFTI_OUTPUT_DISTANCE,(MKL_LONG)1);
DftiComputeForward(rowfft,x);
DftiComputeForward(colfft,x);
Dima
