Traceback MKL ERROR (Environmental variable?)
L__D__Marks
New Contributor II
Is there a MKL environmental variable that will make all errors fatal? I would like to use this to find the location of an error in a large code. (Currently the code completes correctly, the error does not matter.)
Gennady_F_Intel
There are no such variables. You need to check and analyze the return code for each of the separate routines.
