Transformed Values are not correct - MKL FFT Fortran Linux
Giri_Ajay__Adhyanth
Hello!
I was trying to learn about the MKL's FFT Function and wrote a small 1D program to show the forward transformed values. From my understanding, the arguments for the forward function - mentioned in the comment in the program (italicised and not in bold) - should be right and it should perform fine.
When I try to run this, I get 0 as my transformed value (the array y1). Now I am confused about why that happens and what the error in the code is for me to get this error.
Could someone help me to understand the issue?
I am attaching the program file(test.f90), the executable link file (link1.txt - might have to use chmod 700) and the output text file (text.txt).
Thanks!
- Adhyanth
PROGRAM test
!   IMPLICIT NONE
   USE MKL_DFTI
   REAL(KIND = DFTI_DPKP), DIMENSION(201) :: x,y,z
   COMPLEX(KIND = DFTI_DPKP), DIMENSION(201) ::x1, y1
   INTEGER :: i, status
   TYPE(DFTI_DESCRIPTOR), POINTER :: plan
   plan => null()
DO i=1,201
   x(i) = REAL(i-101)/100
   y(i)= 5*SIN(2*x(i))
END DO
OPEN(9, file='text.txt', form = 'FORMATTED')
WRITE(9,*) 'Y values'
WRITE(9,*) y
status = dfti_create_descriptor_1d(plan, DFTI_DOUBLE, DFTI_COMPLEX, 1, 200)
status = dfti_commit_descriptor_external(plan)
DO i=1,201
status = dfti_compute_forward_dz(plan, y(i), y1(i))
!Using the(desc,xreinout,ximinout) argument format
ENDDO
status = dfti_free_descriptor_external(plan)
WRITE(9,*) 'Y1 Values'
WRITE(9,*) y1
WRITE(9,*) 'Y values - After Transform'
WRITE(9,*) y
END PROGRAM test
Khang_N_Intel
Hi Adhyanth,
You are trying to do the R2C out-of-place transform.  However, you are not setting the right parameter values.
DftiSetValue(plan, DFTI_PLACEMENT, DFTI_NOT_INPLACE)
Also, you call the Fortran function directly
dfti_compute_forward_dz(plan, y, y1)
You should call the interface, instead.
Please look at the example basic_dp_real_dft_1d.f90 in the examples folder.
Hope this helps!
Khang
Khang_N_Intel
Hi Adhyanth,
Hope this helps!
Khang
Giri_Ajay__Adhyanth
Hi Khang,
The code worked now. Thanks a ton!
- Adhyanth
Khang_N_Intel
Hi dhyanth,
I am glad that you find it helpful.
Khang
Khang_N_Intel
Hi Adhyanth,
I apologize for typing you name incorrectly.
Khang
Giri_Ajay__Adhyanth
Hey Khang,
No worries.
- Adhyanth
