Transitioning from IMSL to Intel MKL
sooners11
Hi all,
I am trying to transition my code which utilizes IMSL to use MKL
I have this small doubt, as many might be aware, the following statements
COMMON /WORKSP/ RWKSP
REAL RWKSP(7000)
CALL IWKIN(7000)
in IMSL stands for changing the space allocation of data storage for numeric data in the common section.
Is there a an equivalent of this in MKL?
I am not able to find any document covering this aspect of MKL.
VipinKumar_E_Intel
We dont use common sections as this is not thread safe and not used in MKL.
In cases if an additional memory required, MKL does safe allocations inside or a function call to MKL andhas a special parameter to provide a pointer to user allocated workspace. The parameters list is documented for each function with detailed description of workspace size if it is present.
--Vipin
