7303 Discussions
Triangular matrix for BSR format - Only supports continuous row pointer array?
knhkse
Hi!
I have a question about `mkl_sparse_d_trsv` routine.
I usually use BSR format, so I want the triangular solving process using each sub-blocks as a unit.
However, I found that only sparse matrix handle with continuous `pointerB` and `pointerE` arrays gives a right solution.
When I used separated arrays for `pointerB` and `pointerE`, the result gave me `SPARSE_STATUS_NOT_SUPPORTED`.
Sorry for my poor English skill, so here is my simple C code for details.
I compiled with
`icx -L${MKLROOT}/lib -lmkl_rt -lm -ldl sample.c -o sample.x` command.
<sample.c>
#include <stdio.h>
#include "mkl.h"
int main(int argc, char *argv[])
    sparse_matrix_t op1, op2;
    sparse_status_t stat;
    struct matrix_descr ldescr;
    int bn, blk;
    bn = 3;     // Block row length
    blk = 2;    // Block size
     * Simple BSR sparse matrix arrays
     * |1, 0, 6, 7, 0, 0|
     * |2, 1, 8, 2, 0, 0|
     * |0, 0, 1, 4, 0, 0|
     * |0, 0, 5, 1, 0, 0|
     * |0, 0, 4, 3, 7, 2|
     * |0, 0, 0, 8, 0, 5|
    int indptr[4] = {0, 2, 3, 5};       // Continuous array
    int pointerB[3] = {0, 2, 3};        // Separated array
    int pointerE[3] = {2, 3, 5};
    int indices[5] = {0, 1, 1, 1, 2};   // Columns
    double data[20] = {                 // Non-zero values
       1., 0., 2., 1., 6., 7., 8., 2., 1., 4., \
       5., 1., 4., 3., 0., 8., 7., 2., 0., 5.
    // Example arrays
    double x[6] = {1., 2., 3., 4., 5., 6.};
    double y[6] = {0., 0., 0., 0., 0., 0.};
     * 1. Creates BSR handle
     * `op1` : Use continous array (indptr)
     * `op2` : Use separated arrays (pointerB, pointerE)
    stat = mkl_sparse_d_create_bsr(
        &op1, SPARSE_INDEX_BASE_ZERO, SPARSE_LAYOUT_ROW_MAJOR, \
        bn, bn, blk, indptr, &indptr[1], indices, data
    if (stat != SPARSE_STATUS_SUCCESS) return -1;
        &op2, SPARSE_INDEX_BASE_ZERO, SPARSE_LAYOUT_ROW_MAJOR, \
        bn, bn, blk, pointerB, pointerE, indices, data
     * 2. Creates matrix description
     * `ldescr` : Block lower triangular matrix
    ldescr.type = SPARSE_MATRIX_TYPE_BLOCK_TRIANGULAR;
    ldescr.mode = SPARSE_FILL_MODE_LOWER;
    ldescr.diag = SPARSE_DIAG_NON_UNIT;
     * 3. Solves linear system with BSR handles
     * `op1` : stat = 0, expected result
     * `op2` : stat = 6, Error occured
    stat = mkl_sparse_d_trsv(
        SPARSE_OPERATION_NON_TRANSPOSE, 1.0, \
        op1, ldescr, x, y
    printf("Status for `op1` : %d\n", stat);
    for (int i=0; i<6; i++) printf("%.4f ", y[i]);
    printf("\n");
    for (int i=0; i<6; i++) y[i] = 0.0;
        op2, ldescr, x, y
    printf("Status for `op2` : %d\n", stat);
    printf("\n");
    return 0;
<Output>
Status for `op1` : 0
1.0000 0.0000 0.6842 0.5789 -0.0030 0.2737
Status for `op2` : 6
0.0000 0.0000 0.0000 0.0000 0.0000 0.0000
I didn't test every sparse BLAS routines using this circumstance, but the trsv routine is the obvious problem I encountered.
Is there any reason for this? Or, am I missing something?
Thank you.
noffermans
Hi knhkse,
Thank you for reaching out. You are not missing anything and the combination of a BSR matrix in 4-array representation and of a SPARSE_MATRIX_TYPE_BLOCK_TRIANGULAR descriptor type is currently not supported.
Given an input matrix in BSR4 format, one possible workaround is to call the   mkl_sparse_convert_bsr() routine, which will internally convert the matrix to BSR3 format. The modified code below (where op3 is op2 converted to BSR3):
#include <stdio.h>
#include "mkl.h"
    sparse_matrix_t op1, op2, op3;
    int bn, blk;
    // Example arrays
     * Convert op2 in BSR4 format to op3 in BSR3 format
    stat = mkl_sparse_convert_bsr(op2, blk, SPARSE_LAYOUT_ROW_MAJOR, \
                                  SPARSE_OPERATION_NON_TRANSPOSE, &op3);
     * `op3` : stat = 0, expected result
        op1, ldescr, x, y
    printf("\n");
        op2, ldescr, x, y
    printf("\n");
        op3, ldescr, x, y
    printf("Status for `op3` : %d\n", stat);
    printf("\n");
    return 0;
will produce the following output:
Status for `op3` : 0
Hope this helps.
Best,
Nicolas
noffermans
Hi knhkse,
#include <stdio.h>
#include "mkl.h"
    int bn, blk;
    // Example arrays
        op1, ldescr, x, y
    printf("\n");
        op2, ldescr, x, y
    printf("\n");
        op3, ldescr, x, y
    printf("\n");
    return 0;
Hope this helps.
Best,
Nicolas
