7299 Discussions
Trouble installing evaluation copy of MKL in Scientific Linux
meb
Good morning all,
I have downloaded and tried installing the evaluation copy of MKL 10.0 library for use with the intel fortran compiler, for which I have two versions, without success. The installation 'completes' before extracting files. I have seen previous posts in this forum and have contacted premier support but I am still having problems.
My machine uses the KDE desktop application in Scientific Linux, based on Red Hat, which raises the question of compatibility issues, but I have been able to install many other programs such as the compilers and MPI libraries in the past with no problems. Premier support advised me to download a copy of the evaluation license by email and place it in the licenses directory, which I have done, and also to change some environment variables, but no change has been noted. I also tried using the install/install option, but I receive no response from it.
Here is the text output after running install.sh:
Welcome to the Intel Math Kernel Library 10.0 Update 1 for Linux* Installation
Please make your selection by entering an option from the choices below:
1. Install
2. Readme
3. Release Notes
4. Installation Guide
h. Help
x. Exit
Please type a selection: 1
Provide a Serial Number or License File
Please enter your serial number for this Product or select a different option.
Your Serial Number is in XXXX-XXXXXXXX format.
1. Use existing license found on the system. [Recommended]
2. Provide the absolute path for an existing license file.
Use this option if you have obtained a license file instead of a
serial number.
3. Where do I find my Serial Number?
4. Intel Privacy Policy
b. Go Back.
h. Help.
x. Exit.
Please type a selection or Serial Number: VPJK-N6GSN5Z4
The Intel Software Setup Assistant may attempt to connect to the
Intel Software Development Products Registration Center to validate your Serial Number.
This may take several minutes depending on your network. Please wait...
You may press Ctrl+C to cancel.
Installation is complete:
Thank you for using Intel Software Development Products, tools for improving application performance.
Press Enter key to continue...
Here are the contents of some d irectories in the intel folder prior to running:
/opt/intel/fce:
10.1.011 9.1.036
/opt/intel/fce/10.1.011:
bin cluster_omp doc include lib licenses man samples
/opt/intel/fce/10.1.011/licenses:
clredist.txt EVAL_L_MKL__VPJK-N6GSN5Z4.lic flicense fredist.txt
/opt/intel/fce/10.1.011/lib:
crtclusterbegin.o libguide_stats.a libifport.so.5 libirc.a
crtclusterend.o libguide_stats.so libimf.a libirc_s.a
for_main.o libifcore.a libimf.so libirc.so
init.o libifcoremt.a libintlc.so libomp_db.so
libclompc.so libifcoremt_pic.a libintlc.so.5 libompstub.a
libclusterguide.so libifcoremt.so libiomp5.a libompstub.so
libclusterguide_stats.so libifcoremt.so.5 libiomp5.so libsvml.a
libcxaguard.a libifcore_pic.a libiompprof5.a libsvml.so
libcxaguard.so libifcore.so libiompprof5.so locale
libcxaguard.so.5 libifcore.so.5 libiompstubs5.a sharable_init.o
libguide.a libifport.a libiompstubs5.so
libguide.so libifport.so libipgo.a
And finally, here are the contents of my .bashrc file.
source /opt/intel/fce/9.1.036/bin/ifortvars.sh
source /opt/intel/idbe/9.1.042/bin/idbvars.sh
source /opt/intel/cce/9.1.042/bin/iccvars.sh
source /opt/intel/fce/10.1.011/bin/ifortvars.sh
export PATH=.:$PATH:/opt/openmpi/bin:/opt/hdf5/bin
export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/opt/openmpi/lib:/opt/hdf5/lib
export MANPATH=$MANPATH:/opt/openmpi/man
I hope someone can help me, the evaluation is going to run out soon! :)
