Trouble using cblas_dgemm()
craigpod
I'm trying to use cblas_dgemm()_ with Windows Visual Studio 2022 on Windows 11 . I've installed all the latest versions.
I've built a c++ console application. I'm getting the following exception when I call cblas_dgemm()
Unhandled exception at 0x00007FFC7059543C (KernelBase.dll) in CraigsSystem.exe: 0xC06D007E: Module not found (parameters: 0x0000005C3C0FE970).
I've made all of the dlls in the opeAPI mkl bin folder available to the run. I'm linking in mkl_rt.lib.The  application builds and runs. Other LAPACKE functions I'm using work.
What do I need to do to use your Level 1, 2 and 3 cblas functions. I need to multiply, add, subtract, transpose, scale and copy matrices using. I would like to use your parallelized functions
What libraries do I need to link in?
What dlls do I need to include?
Is there any online documentation that provides these details?
Thank you in advance for your help.
Craig
Gennady_F_Intel
You could take a look at the oneMKL Developer Guide follow this link:
https://www.intel.com/content/www/us/en/docs/onemkl/developer-guide-windows/2024-1/linking-your-application-with-onemkl.html
or
You could check oneMKL Linker Adviser ( https://www.intel.com/content/www/us/en/developer/tools/oneapi/onemkl-link-line-advisor.html ) to see how properly link again oneMKL
Gennady_F_Intel
this thread is closing as we see no feedbacks here.
