7303 Discussions
Trouble with installation/use of blas lapack
hervez
I have installed the mkl library on a 64 bits stystem running with Linux Federa 11.
When I try to link to the blas-lapack library, using the following option
--with-blas-lapack-dir=/opt/intel/mkl/10.2.2.025/lib/em64t/
I get the message :
You set a value for --with-blas-lapack-dir=, but /opt/intel/mkl/10.2.2.025/lib/em64t/ cannot be used
What is the problem and How can I solve ?
Thank you in advance
Herve
TimP
You would likely need to consult the link advisor on the right side of the forum header page. If this is an argument to a configure script for some software installation which expects an older version of MKL or a gfortran-compiled lapack such as might be available with a linux distro, you will have to study the situation yourself.
jaewonj
Quoting - hervez
I get the message :
Herve
Try this. It works for me.
./config/configure.py --with-fc=0 --with-mpi=0 --with-blas-lapack-lib=[$MKL_LIB_PATH/libmkl_intel_lp64.a,libmkl_intel_thread.a,libmkl_core.a,libiomp5.a,libpthread.a,libm.a]
Assume libpthread.a and libm.a are installed on your linux box.
Use other than --with-fc=0 and --with-mpi=0 in case you want to use fortran compiler or MPI.
If you're still unable to configure, see $PETSC_DIR/make.log. You will find what went wrong.
Jaewon
Gennady_F_Intel
Quoting - jaewonj
Jaewon
May be the best way to use mklvarsem64t.sh or mklvarsem64t.csh to set all libraries and compilers environment variables (INCLUDE, MKLROOT,LD_LIBRARY_PATH, MANPATH, LIBRARY_PATH, CPATH, FPATH ) in the current user shell....
--Gennady
