Typos in the mkl_spblas.h?
Nishimura__Akihiko
Some of the function declarations in mkl_spblas.h do not agree with the documentation. In particular, in the create and export routines, the parameter names for the CSC format coincide with those for CSR format, which I don't believe accurately describes the nature of the parameters (e.g. `rows_start` and `col_indx` should be `cols_start` and `row_indx`).
Below are a few of the declarations I find in the mkl_spblas.h file:
sparse_status_t mkl_sparse_d_create_csc(
                                             sparse_matrix_t           *A,
                                             const sparse_index_base_t indexing, /* indexing: C-style or Fortran-style */
                                             const MKL_INT             rows,
                                             const MKL_INT             cols,
                                             MKL_INT             *rows_start,
                                             MKL_INT             *rows_end,
                                             MKL_INT             *col_indx,
                                             double              *values );
/* cf. https://software.intel.com/en-us/mkl-developer-reference-c-mkl-sparse-create-csc */
sparse_status_t mkl_sparse_d_export_csc(
                                             const sparse_matrix_t  source,
                                             sparse_index_base_t    *indexing,      /* indexing: C-style or Fortran-style */
                                             MKL_INT                *rows,
                                             MKL_INT                *cols,
                                             MKL_INT                **rows_start,
                                             MKL_INT                **rows_end,
                                             MKL_INT                **col_indx,
                                             double                 **values );
/* cf. https://software.intel.com/en-us/mkl-developer-reference-c-mkl-sparse-export-csc */
Gennady_F_Intel
Yes. Thank you for the notice. We will fix this typos.
Gennady_F_Intel
the issue is escalated and we will keep you informed when the problem will be fixed. thanks again.
