7303 Discussions
Ubuntu 22.04 broken system + unmet dependencies due to Intel driver & software installations
MastaBlasta
Dear Intel,
installing GPU drivers, oneAPI and AI toolkits for my "Intel Arc A730M Graphics" on Ubuntu 22.04 somehow broke my whole system, I sadly face these unmet dependencies:
part 1
$ sudo apt --fix-broken install
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
Correcting dependencies... failed.
The following packages have unmet dependencies:
libegl-dev:i386 : Depends: libegl1:i386 (= 1.7.0-2101~22.04) but 1.4.0-1 is installed
libegl1 : Depends: libglvnd0 (= 1.7.0-2101~22.04) but it is not installed
Breaks: libegl1:i386 (!= 1.7.0-2101~22.04) but 1.4.0-1 is installed
libegl1:i386 : Depends: libglvnd0:i386 (= 1.4.0-1) but 1.7.0-2101~22.04 is installed
Breaks: libegl1 (!= 1.4.0-1) but 1.7.0-2101~22.04 is installed
libgl-dev : Depends: libgl1 (= 1.7.0-2101~22.04) but 1.4.0-1 is installed
Breaks: libgl-dev:i386 (!= 1.7.0-2101~22.04) but 1.4.0-1 is installed
libgl-dev:i386 : Depends: libgl1:i386 (= 1.4.0-1) but 1.7.0-2101~22.04 is installed
Breaks: libgl-dev (!= 1.4.0-1) but 1.7.0-2101~22.04 is installed
libgl1 : Depends: libglvnd0 (= 1.4.0-1) but it is not installed
Depends: libglx0 (= 1.4.0-1) but 1.7.0-2101~22.04 is installed
Breaks: libgl1:i386 (!= 1.4.0-1) but 1.7.0-2101~22.04 is installed
libgl1:i386 : Depends: libglx0:i386 (= 1.7.0-2101~22.04) but 1.4.0-1 is installed
Breaks: libgl1 (!= 1.7.0-2101~22.04) but 1.4.0-1 is installed
libgles-dev : Depends: libegl-dev but it is not installable
Breaks: libgles-dev:i386 (!= 1.7.0-2101~22.04) but 1.4.0-1 is installed
libgles-dev:i386 : Breaks: libgles-dev (!= 1.4.0-1) but 1.7.0-2101~22.04 is installed
libgles1 : Depends: libglvnd0 (= 1.7.0-2101~22.04) but it is not installed
Breaks: libgles1:i386 (!= 1.7.0-2101~22.04) but 1.4.0-1 is installed
libgles1:i386 : Depends: libglvnd0:i386 (= 1.4.0-1) but 1.7.0-2101~22.04 is installed
Breaks: libgles1 (!= 1.4.0-1) but 1.7.0-2101~22.04 is installed
libgles2 : Depends: libglvnd0 (= 1.7.0-2101~22.04) but it is not installed
Breaks: libgles2:i386 (!= 1.7.0-2101~22.04) but 1.4.0-1 is installed
libgles2:i386 : Depends: libglvnd0:i386 (= 1.4.0-1) but 1.7.0-2101~22.04 is installed
Breaks: libgles2 (!= 1.4.0-1) but 1.7.0-2101~22.04 is installed
libglvnd-core-dev : Breaks: libglvnd-core-dev:i386 (!= 1.7.0-2101~22.04) but 1.4.0-1 is installed
libglvnd-core-dev:i386 : Breaks: libglvnd-core-dev (!= 1.4.0-1) but 1.7.0-2101~22.04 is installed
libglvnd-dev : Depends: libglvnd0 (= 1.4.0-1) but it is not installed
Depends: libglvnd-core-dev (= 1.4.0-1) but 1.7.0-2101~22.04 is installed
Depends: libegl-dev (>= 1.3.0-1) but it is not installable
Breaks: libglvnd-dev:i386 (!= 1.4.0-1) but 1.7.0-2101~22.04 is installed
libglvnd-dev:i386 : Depends: libglvnd-core-dev:i386 (= 1.7.0-2101~22.04) but 1.4.0-1 is installed
Breaks: libglvnd-dev (!= 1.7.0-2101~22.04) but 1.4.0-1 is installed
libglx-dev : Breaks: libglx-dev:i386 (!= 1.7.0-2101~22.04) but 1.4.0-1 is installed
libglx-dev:i386 : Breaks: libglx-dev (!= 1.4.0-1) but 1.7.0-2101~22.04 is installed
libglx0 : Depends: libglvnd0 (= 1.7.0-2101~22.04) but it is not installed
Breaks: libglx0:i386 (!= 1.7.0-2101~22.04) but 1.4.0-1 is installed
libglx0:i386 : Depends: libglvnd0:i386 (= 1.4.0-1) but 1.7.0-2101~22.04 is installed
Breaks: libglx0 (!= 1.4.0-1) but 1.7.0-2101~22.04 is installed
libopengl-dev : Depends: libopengl0 (= 1.4.0-1) but 1.7.0-2101~22.04 is installed
Breaks: libopengl-dev:i386 (!= 1.4.0-1) but 1.7.0-2101~22.04 is installed
libopengl-dev:i386 : Depends: libopengl0:i386 (= 1.7.0-2101~22.04) but 1.4.0-1 is installed
Breaks: libopengl-dev (!= 1.7.0-2101~22.04) but 1.4.0-1 is installed
libopengl0 : Depends: libglvnd0 (= 1.7.0-2101~22.04) but it is not installed
Breaks: libopengl0:i386 (!= 1.7.0-2101~22.04) but 1.4.0-1 is installed
libopengl0:i386 : Depends: libglvnd0:i386 (= 1.4.0-1) but 1.7.0-2101~22.04 is installed
Breaks: libopengl0 (!= 1.4.0-1) but 1.7.0-2101~22.04 is installed
E: Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages.
E: Unable to correct dependencies
part 2
In my hopeless attempts to somewhat solve these issue, I followed e.g. https://superuser.com/questions/1386209/how-to-solve-this-dependencies-apt-fix-broken-install
sudo dpkg --force-all --configure -a
sudo dpkg --purge --force-depends libglvnd0
sudo apt-get -f install
The command
$ sudo dpkg --purge --force-depends libglvnd0
triggered this output:
... dependency problems, but removing anyway as you requested
libopengl0:amd64 depends on libglvnd0 (= 1.7.0-2101~22.04).
libglx0:amd64 depends on libglvnd0 (= 1.7.0-2101~22.04).
libglvnd-dev:amd64 depends on libglvnd0 (= 1.4.0-1).
libgles2:amd64 depends on libglvnd0 (= 1.7.0-2101~22.04).
libgles1:amd64 depends on libglvnd0 (= 1.7.0-2101~22.04).
libgl1:amd64 depends on libglvnd0 (= 1.4.0-1).
libegl1:amd64 depends on libglvnd0 (= 1.7.0-2101~22.04).
(Reading database ... 498317 files and directories currently installed.)
Removing libglvnd0:amd64 (1.4.0-1) ...
Processing triggers for libc-bin (2.35-0ubuntu3.6) ...
/sbin/ldconfig.real: /opt/intel/oneapi/compiler/2024.1/opt/oclfpga/host/linux64/lib/libOpenCL.so.1 is not a symbolic link
/sbin/ldconfig.real: /opt/intel/oneapi/mkl/2024.1/lib/libmkl_sycl.so is not an ELF file - it has the wrong magic bytes at the start.
part 3 - I have two questions to Intel:
1. How to solve the two issues with the installed oneAPI version 2024.1 that two object files appear corrupted (not a symbolic link, wrong magic bytes), please?
2. How to solve for the unmet dependencies the Intel driver & software installations caused to my Ubuntu system, please?
Attached a txt file containing the outputs of collect_env.py and env-check.sh
Good luck to all of us,
your user
Vipin_S_Intel
Hi Subi, we have sent you a private message. Kindly check your community inbox.
Vipin_S_Intel
Vipin_S_Intel
Hi Subi, unfortunately, we were unable to hear back from you.
If you have any further queries, please post a new question, as this thread will no longer be monitored by Intel®.
